[Commercial meshers] Issues using Fluent3DMeshToFoam
Old   February 4, 2025, 21:51
Default Issues using Fluent3DMeshToFoam
ry
Ryon is on a distinguished road
Hiya guys, CFD newbie here
I've been trying to get my mesh which was generated using ansys fluent with the Fluen3DMeshToFoam Command. The error I get is:
  • ...Number of points: 30036341
    --> FOAM Warning : Found unknown block of type: "11" ...(Multiple lines of this)
  • ...patch 7 from Fluent indices: 575094 to: 575815 type: velocity-inlet
    Killed... (Not sure if it says killed because of the error above or something else)
A little bit about what I've tried so far:
- The mesh was exported from fluent in ascii (.msh.gz) and then gzip to get .msh file
- tried different meshing types (Poly-hexcore, tetrahedral and polyhedral)
- I am able to reopen the .msh file which I extracted using gzip back in fluent, with no errors and the original workflow being viewable as if the mesh was just made
Anything you guys spot from this that could help me solve this?
Sorry if this post isn't up to standard. I'm new! If you want anymore info just let me know and I'll try my best.
Thanks
Ryon is offline   Reply With Quote
Old   February 5, 2025, 05:55
Alczem is on a distinguished road
Hey,
My usual steps for importing a Fluent mesh to OpenFoam are very similar:
  • Save it as an ASCII .msh (when saving, just delete the .gz at the end and click save, it should still work and you won't need to use gzip)
  • Edit the .msh with a text editor and delete the second-to-last block of text, called (0 "TGrid variables:") between "Cortex variables" and "TGrid meshing". Not sure what it does but it generates errors if you keep it. Note that you won't be able to open the mesh in Fluent Meshing after deleting it, so either keep a copy or make sure you won't need to edit it.
  • Save the modified .msh
  • Import it with fluent3DMeshToFoam
  • I regularly do this and it works like a charm, with boundaries, cellzones and facezones untouched.
Alczem is offline   Reply With Quote
ansys, fluent, fluent3dmeshtofoam
fluent3DMeshToFoam and mergeMeshes crash with large (around 170 mio cells) meshes maxdre91 OpenFOAM Pre-Processing 2 April 27, 2022 09:44
[Other] fluent3DMeshToFoam with ignoreFaceGroups piprus OpenFOAM Meshing & Mesh Conversion 1 May 3, 2021 09:29
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
OpenFOAM command from inside MATLAB sega OpenFOAM Post-Processing 18 September 25, 2012 08:35
