[blockMesh] Failed Burner Mesh
Old   February 6, 2025, 00:04
Default Failed Burner Mesh
Jehan Sharook Rassdeen
Jehan99 is on a distinguished road
Hi everyone, hope you're doing well.
I initially ran my simulation using a wedge-type mesh, and it worked fine. However, after switching to a full burner mesh, I'm encountering multiple errors, including floating-point exceptions.
I've attached images of my full mesh. What improvements should I make to ensure a high-quality mesh for accurate simulations? Any insights on potential issues that could be causing these errors would be greatly appreciated!
Jehan99 is offline   Reply With Quote
Old   February 6, 2025, 03:54
Domenico Lahaye
dlahaye is on a distinguished road
Not sure.
Is error caused by merging front (0 degree) and back (360 degrees) patches? Does same error occur revolving over, say, 180 degrees?
Is it more comfortable to move away from blockMesh and use tools such as cfMesh or GMSH, possibly embedded in Blender?
dlahaye is online now   Reply With Quote
Old   February 6, 2025, 04:07
Originally Posted by dlahaye View Post
Not sure.
Thank you very much for your reply. Is any chance for revolve this wedge mesh and make a full cylinder.
Old   February 6, 2025, 04:23
Domenico Lahaye
Again, not sure.
Searching online might
Possibly post number 17 at Generating 3-D axisymmetric mesh using extrudeMesh
Dixit:
If you do a full 360 extrusion, consider using "mergeFaces true;". For a full 360 extrusion with mergeFaces true, as far as I remember, extrudeMesh automatically fixes the zero face areas that are generated if you have cells in the 2D mesh that lie on the axis of rotation. If not, you can use the collapseEdges utility, which will change the cell shape from hex to whatever shape results from collapsing zero-length edges and zero-area faces.
Old   February 6, 2025, 08:17
Again, not sure.
Dixit:
Thank you very much.
I set the boundary condition to cyclic and run the one-fourth (90 degree) section of a burner. Then it was fine.What is the reason for that?
Old   February 6, 2025, 09:59
Domenico Lahaye
At less than 360 degrees, there is no need to merge two patches into a single path.
Think of trigonometry where it is customary to identify 360 degree as 0 degrees.
One needs to tell blockMesh that at 360 degrees, two patches collapse into a single path.
Do I make sense?
mesh 2d to 3d, wedge mesh axisymmetric
Paraview 5.10.1 - error - openfoam 11 - ubuntu 22.04 lts gu1 OpenFOAM Bugs 5 July 29, 2024 11:50
GAMG crash fxzf OpenFOAM Running, Solving & CFD 6 June 5, 2018 06:09
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
