[snappyHexMesh] How to capture sharp corners on triangles
Old   February 10, 2025, 02:08
Default How to capture sharp corners on triangles
bored
bored_bot is on a distinguished road
This is a two-part question:
1) How much sharpness is required for a simulation
2) How to achieve a specific level of sharpness
I'm trying to simulate a 2d external flow case of a specific triangle arrangement, so basically a 3d case but with one cell thickness. But for some reason, the sharp corners don't mesh well with SHM, and though I know SHM for sharp corners isn't the best, I was instructed to only use SHM. I copied the meshing directories from
/opt/openfoam12/tutorials/incompressibleFluid/wingMotion
After that, I did these things:
1) Increased block mesh resolution
2) Created a surfaceFeaturesDict for the mesh and created Explicit feature edge refinement
    features     (         {             file "birds_60.eMesh";             level 6;         }     );
3) Increased surfaces based refinement
4) Increased nSolveIter to 50
Yet the snapping isn't perfect. The blunt edge still persists. Is it possible to improve this? and is the current quality for any real CFD work? Thank you.
Pictures:
https://imgur.com/a/hzsBINp
bored_bot is offline   Reply With Quote
corners, meshing, sharp edges, snappyhexmesh 2d, triangles
[ICEM] Skewed elements at sharp corners Julian121 ANSYS Meshing & Geometry 3 January 11, 2019 04:55
Unphysical peaks in the pressure field at sharp corners – why? jcamilleri STAR-CCM+ 0 March 5, 2016 06:35
Sharp corners Ford Prefect Main CFD Forum 5 January 31, 2012 13:30
[snappyHexMesh] SnappyHexMesh and sharp corners madad2005 OpenFOAM Meshing & Mesh Conversion 2 September 7, 2009 10:26
Flow near sharp corners Harish Main CFD Forum 4 February 21, 2007 22:55
