[mesh manipulation] Dynamic mesh
Old   February 14, 2025, 05:11
Default Dynamic mesh
Amirreza Niazmehr
Amirreza_pro is on a distinguished road
Hi guys
I want to simulate the oil flow in a roller bearing using OpenFOAM.
For the rotation of both the casing and roller around the central axis, I plan to use dynamic mesh.
In this case, what do you think would be the appropriate AMI interface selection? Since my flow is internal flow, how should I handle this situation?
Should I take the surface of roller and casing as AMI Interface?
In attachment you can find the picture of details.
Amirreza_pro is offline   Reply With Quote
Mesh Disappering with Dynamic Mesh FaroukH FLUENT 0 February 23, 2021 19:26
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
