[Other] Mesh Deformation in Axisymmetric Geometry with moveDynamicMesh |
Rep Power: 0 ![]() |
Dear CFD community,
I am trying to implement what seems to be a simple setup. I have an axisymmetric geometry (a section of a cylinder, as shown in the attached image). Inside this geometry, I have a mixture of water and another liquid-like phase, and I am using interIsoFoam for my simulation. I would like to introduce a pre-conditioned state representing an increase in the diameter of the geometry. My approach was to first run a simulation using the moveDynamicMesh solver, applying a displacement to the top wall to increase the diameter. Then, I intended to save the updated coordinates and field data (velocity, air/liquid ratio, etc.) and use them as the initial condition for a second simulation with my original setup. However, I have encountered an issue: while the top wall moves as expected, the side mesh does not properly follow the displacement, resulting in a highly distorted mesh (as seen in the attached figure). I searched for similar cases in this forum and OpenFOAM tutorials but could not find a satisfactory example. Below you will find my dynamicMeshDict and pointDisplacement files. I would greatly appreciate any help or advice regarding my approach! Thank you so much! Best regards, Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libfvMotionSolvers.so"); solver displacementLaplacian; diffusivity quadratic inverseDistance (topwall); Code:
dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; $internalField; } outlet { type fixedValue; $internalField; } topwall { type uniformFixedValue; uniformValue constant (0 0.002 0); // Moves up by 0.002m } back { type wedge; } front { type wedge; } defaultFaces { type empty; } } // ************************************************************************* // |
axisymmetric, movedynamicmesh, pointdisplacement, pre-conditioning |
Display Modes | |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
