[Sponsors] | |||||
[snappyHexMesh] SnappyHexMesh in parallel for multiregion case |
Giorgio
Rep Power: 4 ![]() |
Hi everybody,
I am trying to generate a mesh with snappyHexMesh in parallel for a multiregion case. I am on OpenFOAM 23.12. I use the tuto cpuCabinet as example, but there the mesh is not created in parallel. The problem is that decomposePar needs the interfaces between the regions that are generated by splitMeshRegions after the mesh is generated. Is there a way to use snappyHexMesh to generate the mesh in parallel for a multiregion case? Thanks in advance |
Yann
Rep Power: 33 ![]() ![]() |
You can have a look at the snappyMultiRegionHeater tutorial to have an example meshed in parallel. $FOAM_TUTORIALS/heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater |
| Tags |
| multi-region mesh, snappyhexmesh |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [snappyHexMesh] Running snappyHexMesh in parallel creates new time directories | hconel | OpenFOAM Meshing & Mesh Conversion | 5 | September 27, 2022 16:20 |
| [snappyHexMesh] snappyHexMesh in parallel | shailesh.nitk | OpenFOAM Meshing & Mesh Conversion | 33 | January 25, 2022 11:35 |
| Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 11:25 |
| [snappyHexMesh] SnappyHexMesh in Parallel problem | swifty | OpenFOAM Meshing & Mesh Conversion | 10 | November 6, 2015 05:40 |
| Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
