[snappyHexMesh] Finished Meshing with illegal Faces.
Old   April 21, 2025, 10:48
Default Finished Meshing with illegal Faces.
Leonhard
Leonhard is on a distinguished road
Hello
I was trying to create a Mesh with snappyHexMesh
but i got a error that i have 22336 illegal faces.
Here is the full output:
Overall mesh bounding box  : (-30 -250 -25) (30 150 25)
Relative tolerance         : 1e-06
Absolute matching distance : 0.000407554
Reading refinement surfaces.
Read refinement surfaces in = 0.02 s
Reading refinement shells.
Refinement level 2 for all cells inside refinementBox
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
For geometry MainBodyDone.stl detected 0 uncached triangles out of 1774
Checked shell refinement in = 0.03 s
Reading features.
Read edgeMesh mainBodyDone.eMesh
    edges       : 163
    boundingBox : (-12.475 -159 -12.475) (12.475 50 12.4709)
Refinement level according to distance to "mainBodyDone.eMesh" (163 points, 163 edges).
    level 3 for all cells within 0 metre.
Read features in = 0.01 s
Determining initial surface intersections
Edge intersection testing:
    Number of edges             : 392000
    Number of edges to retest   : 0
    Number of intersected edges : 0
    Number of edges to retest   : 392000
Calculated surface intersections in = 0.62 s
Initial mesh : cells:128000  faces:392000  points:136161
Cells per refinement level:
    0   128000
Adding patches for surface regions
Patch Type                Region
mainBody:
3     wall                mainBody
Added patches in = 0.02 s
Selecting decompositionMethod none [1]
Refinement phase
Found point (0 -0.1 0) in cell 62040 on processor 0
Feature refinement iteration 0
Marked for refinement due to explicit features             : 204 cells.
Determined cells to refine in = 1.48 s
Selected for feature refinement : 204 cells (out of 128000)
    Number of edges             : 397499
    Number of edges to retest   : 9318
Refined mesh in = 0.38 s
After refinement feature refinement iteration 0 : cells:129428  faces:397499  points:139002
    0   127796
    1   1632
Feature refinement iteration 1
Marked for refinement due to explicit features             : 407 cells.
Determined cells to refine in = 1.35 s
Selected for feature refinement : 691 cells (out of 129428)
    Number of edges             : 415133
    Number of edges to retest   : 27839
Refined mesh in = 0.33 s
After refinement feature refinement iteration 1 : cells:134265  faces:415133  points:147335
    0   127462
    1   3947
    2   2856
Feature refinement iteration 2
Marked for refinement due to explicit features             : 858 cells.
Determined cells to refine in = 1.41 s
Selected for feature refinement : 1670 cells (out of 134265)
    Number of edges             : 456620
    Number of edges to retest   : 65743
Refined mesh in = 0.42 s
After refinement feature refinement iteration 2 : cells:145955  faces:456620  points:166079
    0   127205
    1   5293
    2   7833
    3   5624
Feature refinement iteration 3
Marked for refinement due to explicit features             : 393 cells.
Determined cells to refine in = 1.56 s
Selected for feature refinement : 600 cells (out of 145955)
    Number of edges             : 471341
    Number of edges to retest   : 31202
Refined mesh in = 0.4 s
After refinement feature refinement iteration 3 : cells:150155  faces:471341  points:172599
    0   127163
    1   5448
    2   8904
    3   8640
Feature refinement iteration 4
Marked for refinement due to explicit features             : 153 cells.
Determined cells to refine in = 1.73 s
Selected for feature refinement : 204 cells (out of 150155)
    Number of edges             : 476081
    Number of edges to retest   : 13843
After refinement feature refinement iteration 4 : cells:151583  faces:476081  points:174472
    0   127154
    1   5478
    2   9087
    3   9864
Feature refinement iteration 5
Marked for refinement due to explicit features             : 49 cells.
Determined cells to refine in = 1.67 s
Selected for feature refinement : 63 cells (out of 151583)
    Number of edges             : 477494
    Number of edges to retest   : 5074
Refined mesh in = 0.43 s
After refinement feature refinement iteration 5 : cells:152024  faces:477494  points:174988
    0   127151
    1   5491
    2   9126
    3   10256
Feature refinement iteration 6
Marked for refinement due to explicit features             : 23 cells.
Determined cells to refine in = 1.59 s
Selected for feature refinement : 29 cells (out of 152024)
    Number of edges             : 478139
    Number of edges to retest   : 2316
After refinement feature refinement iteration 6 : cells:152227  faces:478139  points:175219
    0   127149
    1   5503
    2   9135
    3   10440
Feature refinement iteration 7
Marked for refinement due to explicit features             : 7 cells.
Determined cells to refine in = 1.66 s
Selected for feature refinement : 9 cells (out of 152227)
    Number of edges             : 478337
    Number of edges to retest   : 783
Refined mesh in = 0.41 s
After refinement feature refinement iteration 7 : cells:152290  faces:478337  points:175288
    0   127149
    1   5501
    2   9144
    3   10496
Feature refinement iteration 8
Marked for refinement due to explicit features             : 3 cells.
Determined cells to refine in = 1.55 s
Selected for feature refinement : 3 cells (out of 152290)
    Number of edges             : 478400
    Number of edges to retest   : 296
Refined mesh in = 0.39 s
After refinement feature refinement iteration 8 : cells:152311  faces:478400  points:175307
    0   127149
    1   5501
    2   9141
    3   10520
Feature refinement iteration 9
Marked for refinement due to explicit features             : 0 cells.
Selected for feature refinement : 0 cells (out of 152311)
Stopping refining since too few cells selected.
Surface refinement iteration 0
Marked for refinement due to surface intersection          : 0 cells.
Marked for refinement due to curvature/regions             : 0 cells.
Determined cells to refine in = 0.01 s
Selected for refinement : 0 cells (out of 152311)
Removing mesh beyond surface intersections
Setting cellZones according to locationsInMesh:
    cellZone : none
For cellZone none found point (0 -0.1 0) in global region 0 out of 1 regions.
Keeping all cells containing inside points
Selected for keeping : 152311 cells.
    cellZone : none
Shell refinement iteration 0
Marked for refinement due to distance to explicit features : 0 cells.
Marked for refinement due to refinement shells             : 0 cells.
Determined cells to refine in = 0.76 s
Selected for internal refinement : 25 cells (out of 152311)
    Number of edges             : 478925
    Number of edges to retest   : 2276
Refined mesh in = 0.37 s
After refinement shell refinement iteration 0 : cells:152486  faces:478925  points:175482
    0   127124
    1   5701
    2   9141
    3   10520
Shell refinement iteration 1
Determined cells to refine in = 0.03 s
Selected for internal refinement : 0 cells (out of 152486)
Dangling coarse cells refinement iteration 0
Selected for refinement : 0 cells (out of 152486)
Determined cells to refine in = 0 s
Refinement transition refinement iteration 0
Splitting mesh at surface intersections
Introducing baffles for 0 faces that are intersected by the surface.
    cellZone : none
Created baffles in = 0.22 s
After introducing baffles : cells:152486  faces:478925  points:175482
    0   127124
    1   5701
    2   9141
    3   10520
Introducing baffles to block off problem cells
--> FOAM Warning :
    From Foam::labelList Foam::meshRefinement::nearestPatch(const labelList&) const
    in file meshRefinement/meshRefinement.C at line 460
    Did not visit some faces, e.g. face 0 at (29.25 145 -24.375)
Assigning these faces to patch 3
markFacesOnProblemCells : marked 0 additional internal faces to be converted into baffles.
Analyzed problem cells in = 0.27 s
Introducing baffles to delete problem cells.
Created baffles in = 0.04 s
    0   127124
    1   5701
    2   9141
    3   10520
    cellZone : none
Remove unreachable sections of mesh
Split mesh in = 0.08 s
After subsetting : cells:152486  faces:478925  points:175482
    0   127124
    1   5701
    2   9141
    3   10520
Introducing zones for interfaces
    cellZone : none
Setting faceZones according to neighbouring cellZones:
Handling cells with snap problems
    cellZone : none
Created baffles in = 0.42 s
    0   127124
    1   5701
    2   9141
    3   10520
--> FOAM Warning :
Analyzed problem cells in = 0.26 s
Created baffles in = 0.07 s
    0   127124
    1   5701
    2   9141
    3   10520
    cellZone : none
Split mesh in = 0.1 s
    0   127124
    1   5701
    2   9141
    3   10520
Merge free-standing baffles
freeStandingBaffles : detected 0 free-standing baffles out of 0
Detected free-standing baffles : 0
Merged free-standing baffles in = 0.01 s
dupNonManifoldPoints : Found : 0 non-manifold points (out of 175482)
Detected unsplittable baffles : 0
Merge refined boundary faces
Merging 0 sets of faces.
No faces merged ...
Merging all points on surface that
- are used by only two boundary faces and
- make an angle with a cosine of more than 0.707107.
No straight edges simplified and no points removed ...
Refined mesh : cells:152486  faces:478925  points:175482
    0   127124
    1   5701
    2   9141
    3   10520
Writing mesh to time 1
Wrote mesh in = 0.16 s.
Mesh refined in = 21.84 s.
Checking final mesh ...
Checking faces in error :
    non-orthogonality > 65  degrees                        : 22336
    faces with face pyramid volume < 1e-13                 : 0
    faces with face-decomposition tet quality < 1e-15      : 0
    faces with concavity > 80  degrees                     : 0
    faces with skewness > 4   (internal) or 20  (boundary) : 0
    faces with interpolation weights (0..1)  < 0.02        : 0
    faces with volume ratio of neighbour cells < 0.01      : 0
    faces with face twist < 0.02                           : 0
    faces with triangle twist < 0.3                        : 0
    faces on cells with determinant < 0.001                : 0
Finished meshing with 22336 illegal faces (concave, zero area or negative cell pyramid volume)
Finished meshing in = 23.37 s.
End
And thats my dict:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
	version	 2.0;
	format	 ascii;
	class	 dictionary;
	object	 snappyHexMeshDict;
castellatedMesh	true;
snap		true;
addLayers	true;
mergeTolerance 1e-6;
geometry
	MainBodyDone.stl
	    type triSurfaceMesh;
	    name mainBody;
	    scale 0.001;
	refinementBox
	    type box;
	    min (-1.0 -1.0 0.0);
	    max (1.0 1.0 1.0);
castellatedMeshControls
    maxLocalCells 100000;
    maxGlobalCells 2000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 3;
    features
	    file "mainBodyDone.eMesh";
	    level 6;
    refinementSurfaces
	mainBody
	    level (5 6);
	    patchInfo
		type wall;
    resolveFeatureAngle 30;
    refinementRegions
	refinementBox
	    mode	inside;
	    levels	((1E15 4));
    locationInMesh (0 -158 -12.2);
    allowFreeStandingZoneFaces true;
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
    nFeatureSnapIter 10;
    implicitFeatureSnap false;
    explicitFeatureSnap true;
    multiRegionFeatureSnap false;
addLayersControls
    relativeSizes true;
    layers
	mainBody
	    nSurfaceLayers 3;
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 0;
    featureAngle 60;
    slipFeatureAngle 30;
    nRelaxIter 3;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedialAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
meshQualityControls
    maxNonOrtho		65;
    maxBoundarySkewness	20;
    maxInternalSkewness	4;
    maxConcave		80;
    minVol		1e-13;
    minTetQuality	1e-15;
    minArea		-1;
    minTwist		0.02;
    minDeterminant	0.001;
    minFaceWeight	0.02;
    minVolRatio		0.01;
    minTriangleTwist	0.3;
    nSmoothScale	4;
    errorReduction	0.75;
Could anyone help me in fixing this issue.
Leonhard is offline   Reply With Quote
illegalfaces, open foam, snappy hex mesh
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
