[snappyHexMesh] SnappyHexMesh creates extra patch on a multi-region problem
Old   June 13, 2025, 06:05
Default SnappyHexMesh creates extra patch on a multi-region problem
Giorgio
giorgianig is on a distinguished road
Dear all,
I am running a multiregion case with 7 regions, nested one inside the other. The most inner region is called Piege. I am struggling to obtain a valid mesh as snappyHexMesh generates an extra patch with very few faces called Piege as it were an external surface. Here is part of the checkMesh output:
HTML Code:
Checking patch topology for multiply connected surfaces...
Patch    Faces   Points  Surface topology
Cont_ext_bot    84036    85201  ok (non-closed singly connected)
Cont_ext_lat   400200   403913  ok (non-closed singly connected)
Cont_ext_top    84036    85201  ok (non-closed singly connected)
Piege        2        4      ok (closed singly connected)
".*"   568274   571991      ok (closed singly connected)
The other three patch "Cont_ext_blabla" are correct, they are the external surfaces of the most external region.
I managed to visualize this Piege patch in Paraview and it is composed by two very small faces. The mesh is of very good quality.
Does anyone ever had a similar behaviour?
Thanks in advance.
giorgianig is offline   Reply With Quote
Old   June 13, 2025, 06:41
Giorgio
Additional info, between the .stl that I use to define the geometry there's one called Piege. I have seen that at the beginning snappyHexMesh generate a patch for each .stl, so I guess the internal ones used to define the boundaries between regions are collapsed during the mesh computation as internal faces. So probably for some reason a couple of faces of the patch Piege are not collapsed.
No idea why though.
Maybe I can force the collapsing of these two extra faces?
How to adress boundary patch from another region in chtMultiRegionFoam? Aniy OpenFOAM Programming & Development 1 October 7, 2021 07:56
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
[snappyHexMesh] SnappyHexMesh Patch Problem Perschr OpenFOAM Meshing & Mesh Conversion 0 October 8, 2016 12:09
[snappyHexMesh] Multi region meshing with SHM creates extra regions Dav3dum OpenFOAM Meshing & Mesh Conversion 0 August 8, 2016 08:54
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
