[Sponsors] | |||||
[Other] Mixing plane in OpenFOAM-v2412 - issue with twg_checkMesh |
#1 | |
Yann
Rep Power: 32 ![]() ![]() |
Hello all,
I'm currently experimenting with mixing planes in OpenFOAM-v2412 thanks to the port from foam-extend provided by the Turbomachinary Special Interest Group. I'm simulating an axial fan and my air intake is basically a pipe at the center of the fan. So I end up with the axis of rotation being inside one of the faces of my mixing plane interface. (see 1st pic attached) This is covered by the very useful documentation here: Quote:
coupledPolyPatch patches:
Checking mixingPlane patch : mrf-interface-out_master for facet intersecting the r=0 axis.
Checking mixingPlane patch : mrf-interface-out_slave for facet intersecting the r=0 axis.
Checking mixingPlane patch : mrf-interface-in_master for facet intersecting the r=0 axis.
*** Not OK. MixingPlane patch mrf-interface-in_master requires a discretization point at r=0: (0 0.500578 0.44) for face index: 17434195
*** Writing a new modifyMeshDict entry for fixing this issue
Checking mixingPlane patch : mrf-interface-in_slave for facet intersecting the r=0 axis.
Checking mixingPlane patch : mrf-interface-side_master for facet intersecting the r=0 axis.
Checking mixingPlane patch : mrf-interface-side_slave for facet intersecting the r=0 axis.
The following step with twg_modifyMesh is working fine and it does retriangulate the face to add a point on the axis of rotation (2nd pic). Has anyone ever experienced this or has an idea of where is the issue? Thanks, Yann |
Martin Beaudoin
Rep Power: 23 ![]() |
This looks like a bug (maybe), or a tolerance parameter issue related to this specific mesh (probably). Would you mind sharing your mesh? It would be easier for me to check this. Martin |
Martin Beaudoin
And by the way, the best way to report those kind of issues with the TurboWG version of the mixingPlane is to use the TurboWG Ticket tracker tool: https://sourceforge.net/p/turbowg/tickets/
I will receive a message as soon as you submit your ticket. Much quicker... Martin |
Yann
Hello Martin,
Thanks for your answer and sorry for the delay. I had to put this project on hold and I just got back to it. I wasn't sure if it was worth opening a ticket on the bug tracker as it might just be a mistake on my side. However I followed your advice and created a ticket with a simplified case reproducing the issue here: https://sourceforge.net/p/turbowg/tickets/11/ Thanks for your help! Yann |
#5 | |
Martin Beaudoin
Hello Yann,
Thank you for sharing a simplified mesh replicating the problem. I'll have a look. Martin Quote:
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
| OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
| OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
| Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
| Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 08:16 |
