[Sponsors] | |||||
[blockMesh] Mesh has 2 geometric (non-empty/wedge) directions (1 0 1) |
Eray Sari
Rep Power: 2 ![]() |
Hi everyone,
I am studying a benchmark problem and to learn better, I created a little bit complicated mesh to the system. Problem is that, with this mesh, OpenFOAM only sees 2 geometric directions as it can be understood from "Mesh has 2 geometric (non-empty/wedge) directions (1 0 1)" when I check it with checkMesh command. Also there is an error s.t. "***Number of edges not aligned with or perpendicular to non-empty directions: 157440 <<Writing 160638 points on non-aligned edges to set nonAlignedEdges" I would really appreciate if someone can help me. I added my blockMesh file as an attachment. When I open it on ParaView, everything looks OK, but it gave these errors in checkMesh command. -------------------------------------------------------------------------------------------------------------------------------------------------- eray$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2506 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _615aae61-20250627 OPENFOAM=2506 version=2506 Arch : "LSB;label=32;scalar=64" Exec : checkMesh Date : Nov 30 2025 Time : 03:26:27 Host : eray-linux PID : 13324 I/O : uncollated Case : /home/eray/me485/2D nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Check mesh... Time = 0 Mesh stats points: 350960 faces: 1014700 internal faces: 977300 cells: 332000 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 332000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 5200 5412 ok (non-closed singly connected) outlet 2800 2911 ok (non-closed singly connected) frontAndBack 16600 17120 ok (non-closed singly connected) pipeWall 10400 10783 ok (non-closed singly connected) defaultFaces 2400 2460 ok (non-closed singly connected) ".*" 37400 37400 ok (closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... No pointZones found. Checking geometry... Overall domain bounding box (-0.12 -0.12 0) (0.33 0.06 0.12) Mesh has 1 geometric (non-empty/wedge) directions (1 0 0) Mesh has 1 solution (non-empty) directions (1 0 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 157440 <<Writing 160638 points on non-aligned edges to set nonAlignedEdges Boundary openness (-1.35734e-16 -2.18955e-15 -3.38552e-18) OK. Max cell openness = 2.14357e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 3.80027e-08. Maximum face area = 0.000209202. Face area magnitudes OK. Min volume = 1.14008e-10. Max volume = 6.27607e-07. Total volume = 0.003672. Cell volumes OK. Mesh non-orthogonality Max: 44.7121 average: 15.5994 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.0665 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
Michael Häckel
I tested your blockMeshDict with OpenFOAM v13. There already blockMesh fails. The reason is that at the marked position the cells do not fit together.
blockMesh.jpg |
Eray Sari
First thank you very much for testing my code. Yeah I corrected what you mentioned and there are some other issues that I found out. (I have been searching for the problem for like 4 hrs idk) Because of my weird blocking, blockMesh creates a defaultFace in the flow area and it also creates a problem. I cannot figure out by editting the code since it became to messy, so I rewrote the code and now it works perfectly. If anyone interested, I attached the new version of it. Thank you Michael. Have a nice day. Code:
| \\ / O peration | Version: v2506 |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
//Editted at 30 Nov 2025, 2:12 PM//
scale 0.03;
vertices
(-4 2 0)
(-0.5 2 0)
(0.5 2 0)
(1.5 2 0)
(11 2 0)
(-4 1.5 0)
(-0.5 1.5 0)
(0.5 1.5 0)
(1.5 1.5 0)
(11 1.5 0)
(-4 0.5 0)
(-0.5 0.5 0)
(0.5 0.5 0)
(1.5 0.5 0)
(11 0.5 0)
(-4 0 0)
(-0.5 0 0)
(0 0 0)
(1 0 0)
(1.5 0 0)
(11 0 0)
(0 -0.5 0)
(0.5 -0.5 0)
(1 -0.5 0)
(0 -4 0)
(0.5 -4 0)
(1 -4 0)
(-4 2 2)
(-0.5 2 2)
(0.5 2 2)
(1.5 2 2)
(11 2 2)
(-4 1.5 2)
(-0.5 1.5 2)
(0.5 1.5 2)
(1.5 1.5 2)
(11 1.5 2)
(-4 0.5 2)
(-0.5 0.5 2)
(0.5 0.5 2)
(1.5 0.5 2)
(11 0.5 2)
(-4 0 2)
(-0.5 0 2)
(0 0 2)
(1 0 2)
(1.5 0 2)
(11 0 2)
(0 -0.5 2)
(0.5 -0.5 2)
(1 -0.5 2)
(0 -4 2)
(0.5 -4 2)
(1 -4 2)
//Boundary Layer
bl_y 30;
bl_grading 10; // >1
bl_gra_z 0.1; // <1
bl_gra_b #eval{1/$bl_grading};
bl_gra_t #eval{1*$bl_grading};
bl_gra_l #eval{1*$bl_grading};
bl_gra_r #eval{1/$bl_grading};
//Mid Blocks
mid_y 10;
mid_x 15;
mid_xt #eval{2*$mid_x};
//Right-Hand Side of the Mid Block
right_x 10;
right_gra 10; // >1
//Left-Hand Side of the Mid Block
left_x 10;
left_gra 0.1; // <1
//Small Pipe Joint
pipe_joint 50;
//Small Pipe Far
pipe_far 30;
pipe_gra 5; // <1
//z-Axis
z_mesh 40;
blocks
hex (0 5 6 1 27 32 33 28) ($bl_y $left_x $z_mesh) simpleGrading ($bl_gra_t $left_gra $bl_gra_z) //1
hex (1 6 7 2 28 33 34 29) ($bl_y $mid_x $z_mesh) simpleGrading ($bl_gra_t 1 $bl_gra_z) //2
hex (2 7 8 3 29 34 35 30) ($bl_y $mid_x $z_mesh) simpleGrading ($bl_gra_t 1 $bl_gra_z) //3
hex (3 8 9 4 30 35 36 31) ($bl_y $right_x $z_mesh) simpleGrading ($bl_gra_t $right_gra $bl_gra_z) //4
hex (5 10 11 6 32 37 38 33) ($mid_y $left_x $z_mesh) simpleGrading (1 $left_gra $bl_gra_z) //5
hex (6 11 12 7 33 38 39 34) ($mid_y $mid_x $z_mesh) simpleGrading (1 1 $bl_gra_z) //6
hex (7 12 13 8 34 39 40 35) ($mid_y $mid_x $z_mesh) simpleGrading (1 1 $bl_gra_z) //7
hex (8 13 14 9 35 40 41 36) ($mid_y $right_x $z_mesh) simpleGrading (1 $right_gra $bl_gra_z) //8
hex (10 15 16 11 37 42 43 38) ($bl_y $left_x $z_mesh) simpleGrading ($bl_gra_b $left_gra $bl_gra_z) //9
hex (11 16 17 12 38 43 44 39) ($bl_y $mid_x $z_mesh) simpleGrading ($bl_gra_b 1 $bl_gra_z) //10
hex (12 18 19 13 39 45 46 40) ($bl_y $mid_x $z_mesh) simpleGrading ($bl_gra_b 1 $bl_gra_z) //11
hex (13 19 20 14 40 46 47 41) ($bl_y $right_x $z_mesh) simpleGrading ($bl_gra_b $right_gra $bl_gra_z) //12
hex (17 21 22 12 44 48 49 39) ($pipe_joint $bl_y $z_mesh) simpleGrading (1 $bl_gra_l $bl_gra_z) //13
hex (12 22 23 18 39 49 50 45) ($pipe_joint $bl_y $z_mesh) simpleGrading (1 $bl_gra_r $bl_gra_z) //14
hex (21 24 25 22 48 51 52 49) ($pipe_far $bl_y $z_mesh) simpleGrading ($pipe_gra $bl_gra_l $bl_gra_z) //15
hex (22 25 26 23 49 52 53 50) ($pipe_far $bl_y $z_mesh) simpleGrading ($pipe_gra $bl_gra_r $bl_gra_z) //16
boundary
inletMain
type patch;
faces
(0 5 32 27)
(5 10 37 32)
(10 15 42 37)
inletSmall
type patch;
faces
(24 25 52 51)
(25 26 53 52)
outlet
type patch;
faces
(4 9 36 31)
(9 14 41 36)
(14 20 47 41)
symmetryWall
type wall;
faces
(0 5 6 1)
(1 6 7 2)
(2 7 8 3)
(3 8 9 4)
(5 10 11 6)
(6 11 12 7)
(7 12 13 8)
(8 13 14 9)
(10 15 16 11)
(11 16 17 12)
(12 18 19 13)
(13 19 20 14)
(17 21 22 12)
(12 22 23 18)
(21 24 25 22)
(22 25 26 23)
pipeWall
type wall;
faces
//Front Face
(27 28 33 32)
(28 29 34 33)
(29 30 35 34)
(30 31 36 35)
(32 33 38 37)
(33 34 39 38)
(34 35 40 39)
(35 36 41 40)
(37 38 43 42)
(38 39 44 43)
(39 40 46 45)
(40 41 47 46)
(44 39 49 48)
(39 45 50 49)
(48 49 52 51)
(49 50 53 52)
//Top Face
(0 27 28 1)
(1 28 29 2)
(2 29 30 3)
(3 30 31 4)
//Bottom Face
(15 16 43 42)
(16 17 44 43)
(18 19 46 45)
(19 20 47 46)
//Inlet Left
(17 21 48 44)
(21 24 51 48)
//Inlet Right
(23 18 45 50)
(26 23 50 53)
| Tags |
| blockmesh, checkmesh, openfoam |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 12:33 |
| how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
| decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
| Simulating fire in a tunnel | luca1992 | OpenFOAM | 14 | August 16, 2017 14:50 |
| [Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
