[Sponsors] | |||||
[snappyHexMesh] Attempting to lower skew, with some issues |
Noah
Rep Power: 0 ![]() |
Hello! I am working on running CFD on a road bicycle frame with wheels, to see the effects of certain changes in the frame on its aerodynamics. I have chosen to use OpenFOAM with FreeCad 1.0.2 and CfdOF, and I am using snappyHexMesh.
The model is quite complex, and I have made some effort to remove bodies that add complexity with little relevance to the analysis. Using Fusion 360 I export as STEP and import into FreeCAD. I made a compound of the bicycle model and the rectangular space where the bike resides. I have tried meshing with other meshers available in FreeCad CfdOF, but snappyHexMesh is the only one to successfully mesh. Upon checking the mesh, I am getting a maximum skewness from 5-10 in most cases, which fails the mesh check. When I try to refine my mesh further to reduce the skew, snappyHexMesh will often freeze on "Introducing zones for interfaces", and not continue. To summarize, I am running a base element size of 50mm, often refining down to around 0.1 relative element size on the surface refinements of the bicycle components. I have stayed with 3 cells between levels, explicit edge detection, and no edge refinement. When I try and go below 0.1 relative, snappy freezes and does not continue. ![]() Here is a snappyHexMeshDict for a recent mesh of mine, which gave a max skew of about 5.46: Code:
| Generated by the CfdOF workbench for FreeCAD |
| https://github.com/jaheyns/CfdOF |
FoamFile
version 4.0;
format ascii;
class dictionary;
location "system";
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry
"Compound_Geometry.stl"
type triSurfaceMesh;
name Compound_Geometry;
file "Compound_Geometry.stl";
regions
patch_0_1
name patch_0_1;
patch_0_2
name patch_0_2;
patch_0_3
name patch_0_3;
patch_1_0
name patch_1_0;
patch_2_0
name patch_2_0;
patch_3_0
name patch_3_0;
"MeshRefinement.stl"
name MeshRefinement;
file "MeshRefinement.stl";
"MeshRefinement001.stl"
name MeshRefinement001;
file "MeshRefinement001.stl";
"MeshRefinement002.stl"
name MeshRefinement002;
file "MeshRefinement002.stl";
castellatedMeshControls
maxLocalCells 100000000;
maxGlobalCells 2000000000;
minRefinementCells 0;
nCellsBetweenLevels 3;
maxLoadUnbalance 0.20;
features
file "Compound_Geometry.eMesh";
level 0;
file "MeshRefinement.eMesh";
level 0;
file "MeshRefinement001.eMesh";
level 0;
file "MeshRefinement002.eMesh";
level 0;
refinementSurfaces
Compound_Geometry
level (0 0);
MeshRefinement
level (4 4);
faceZone MeshRefinement;
MeshRefinement001
level (4 4);
faceZone MeshRefinement001;
MeshRefinement002
level (4 4);
faceZone MeshRefinement002;
resolveFeatureAngle 30;
refinementRegions
locationInMesh (0.0 0.0 0.0);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 3;
tolerance 1.0;
nSolveIter 100;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
addLayersControls
relativeSizes true;
layers
expansionRatio 1.2;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 0;
featureAngle 120;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality -1;
minArea -1;
minTwist 0.01;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
relaxed
maxNonOrtho 75;
mergeTolerance 1e-6;
18:02:48 End
18:02:48 Executing: checkMesh -meshQuality in C:\Users\nohda\AppData\Local\Temp\meshCase
18:03:20 /*---------------------------------------------------------------------------*\
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 12
\\/ M anipulation |
/* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\
| Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
Build : 12-8e8552546d20
Exec : checkMesh -meshQuality
Date : Dec 07 2025
Time : 18:03:20
Host : "NOHRIGG"
PID : 43976
I/O : uncollated
Case : C:/Users/nohda/AppData/Local/Temp/meshCase
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From function static Foam::instantList Foam::timeSelector::select0(Foam::Time&, const Foam::argList&)
in file db/Time/timeSelector.C at line 269
No time specified or available, selecting 'constant'
Create polyMesh for time = constant
18:03:20 Enabling user-defined geometry checks.
18:03:31 Time = constant
18:03:31 Mesh stats
faces: 6641921
internal faces: 6524876
cells: 2189733
faces per cell: 6.01296916108037
boundary patches: 6
point zones: 0
face zones: 3
cell zones: 0
Overall number of cells of each type:
hexahedra: 2176117
prisms: 425
wedges: 0
pyramids: 0
tet wedges: 2
tetrahedra: 0
polyhedra: 13189
Breakdown of polyhedra by number of faces:
faces number of cells
4 886
5 1536
6 3673
9 4553
12 1525
15 955
18 61
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
18:03:31 Point usage OK.
18:03:32 Upper triangular ordering OK.
18:03:32 Face vertices OK.
18:03:34 Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
patch_0_1 6374 7217 multiply connected (shared edge)
patch_0_2 7492 8482 ok (non-closed singly connected)
patch_0_3 1637 1811 multiply connected (shared edge)
patch_1_0 12051 12272 ok (non-closed singly connected)
patch_2_0 12051 12272 ok (non-closed singly connected)
patch_3_0 77440 77880 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-2.96645712852478 -1.16999995708466 -0.805481016635895) (0.541160702705383 1.16999995708466 1.24515795707703)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
18:04:12 Max cell openness = 3.4554989943061e-16 OK.
Max aspect ratio = 7.84703747468256 OK.
Minimum face area = 2.78960374638515e-08. Maximum face area = 0.000478492562917788. Face area magnitudes OK.
Min volume = 2.47891579817589e-08. Max volume = 9.6185816079543e-06. Total volume = 16.8191569129124. Cell volumes OK.
Mesh non-orthogonality Max: 64.7241437838534 average: 2.35993054673786
Non-orthogonality check OK.
18:04:13 Face pyramids OK.
***Max skewness = 4.82949782233829, 1 highly skew faces detected which may impair the quality of the results
Coupled point location match (average 0) OK.
Checking faces in error :
18:04:15 non-orthogonality > 90 degrees : 0
18:04:15 faces with face pyramid volume < 0 : 0
18:04:16 faces with concavity > 90 degrees : 0
18:04:16 faces with skewness > 50 (internal) or 100 (boundary) : 0
faces with interpolation weights (0..1) < 0.0001 : 0
faces with volume ratio of neighbour cells < 0.0001 : 0
18:04:17 faces on cells with determinant < 0 : 0
18:04:17
Failed 1 mesh checks.
End
18:04:17
Introducing baffles to delete problem cells.
18:19:53 Edge intersection testing:
Number of edges : 24981346
18:20:03 Number of edges to retest : 7176955
18:20:03 Number of intersected edges : 3545085
18:20:06 Created baffles in = 13.715 s
18:20:06
18:20:06 After introducing baffles : cells:6758398 faces:24981346 points:7820483
18:20:07 Cells per refinement level:
18:20:07 0 2328737
1 92109
2 299683
3 530281
4 3507588
18:20:07 Remove unreachable sections of mesh
18:20:07 Keeping all cells in regions containing any point in 1((0 0 0))
18:20:27 Selected for keeping : 5324409 cells.
18:20:27 Edge intersection testing:
Number of edges : 16932619
18:20:33 Number of edges to retest : 0
18:20:33 Number of intersected edges : 904445
18:20:33 Split mesh in = 26.377 s
18:20:33 After subsetting : cells:5324409 faces:16932619 points:6257126
18:20:33 Cells per refinement level:
18:20:33 0 2102050
1 92090
2 272538
3 515300
4 2342431
Surface : MeshRefinement
faceZone : MeshRefinement
cellZone :
Surface : MeshRefinement001
faceZone : MeshRefinement001
cellZone :
Surface : MeshRefinement002
faceZone : MeshRefinement002
cellZone :
18:20:33 Walking from locations-in-mesh 1((0 0 0)) to assign cellZones - crossing a faceZone face changes cellZone
18:20:34
18:20:34 Found point (0 0 0) in global region 0 out of 1 regions.
18:20:50 Detected 802903 free-standing zone faces
18:20:51
M
Rep Power: 14 ![]() |
I have tried several OF solvers with meshes of skew up to 12. None of it fails or produces bad output as long as you are under 12 and its a non-significant ratio of the total cells. Usually its some spot or a few spots with only a few cells.
Go for the simulation, check p is converging and you should be good. 1 cell > 4 is a dream
Rep Power: 7 ![]() |
Hey,
The brake disc looks all choppy and poorly meshed, are you sure it is propely resolved? I would try to either remove it or thicken it a bit if you cannot afford to refine the mesh at this location. |
#4 | ||
Noah
![]() Quote:
I did not think to thicken the disc a bit! I will give that a shot. In hindsight I made this post in a bit of a panic and have since made good progress on my case. I will create another post once I require some more feedback and advice. Thanks to you both and best wishes to your new year!
| Tags |
| freecad, openfoam, skewness |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [snappyHexMesh] Skew Faces in Mesh | CfdUser5855 | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2022 09:55 |
| Temperature lower than possible in closed domain | Czarulla | Main CFD Forum | 1 | January 15, 2015 06:01 |
| [snappyHexMesh] upper and lower patch for a 0_thick Membrane in a wind tunnel | hfs | OpenFOAM Meshing & Mesh Conversion | 7 | October 15, 2013 17:41 |
| Lower heating value | Andrea | Siemens | 2 | July 30, 2007 08:19 |
| equiangle skew with tetrahedral cells | Wouter | FLUENT | 0 | December 7, 2005 06:03 |
