Launching patchTool
I am having trouble launching patchTool. I am a new user of OpenFOAM, and am not particularly competant with linux so it is likley that the problem is quite simple. On trying to launch patchTool I get the following infomration in the shell window: james-1.4/run> patchTool . device-steady/ runPatchToolServer : pid:8263 Using running runPatchToolServer (pid 8263) ... Using jar /home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/patch Tool/lib/j3d-org.jar Using jar /home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/patch Tool/lib/PatchTool.jar + /usr/bin/java -cp .:/home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/pat chTool/lib/j3d-org.jar:/home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/ mesh/manipulation/patchTool/lib/PatchTool.jar -DFoamX.SystemPath=/home/james/OpenFOAM/OpenFOAM-1.4 -DFoamX.SystemConfigPath=/home/james/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/Fo amX -DFoamX.UserConfigPath=/home/james/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/Foam X -DFoamX.PatchToolPath=/home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/m esh/manipulation/patchTool PatchTool/PatchTool -ORBDefaultInitRef corbaloc:iiop:1.0:linux:1235 Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/j3d/Node + cleanup + trap 0 2 3 15 + '[' '' ']' james-1.4/run> Any ideas on what I have done wrong? Thanks James |
Probably this is because you h
Probably this is because you have an extra "/" in the case name. You should type:
patchTool ./ device-steady |
Hi Dragos,
Same problem. I
Hi Dragos,
Same problem. I have tried quite a few different variations on the cmd line, all give the same error which I think comes down to this line: Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/j3d/Node Do you know what that means? |
Hm, no idea! But is seems ther
Hm, no idea! But is seems there is something wrong with the java installation. Is FoamX running correctly?
Dragos |
Yeah it sounds possible, howev
Yeah it sounds possible, however both FoamX and paraFoam work perfectly.
Pehaps there is another way to achieve what I am trying to do. I have a single patch (a pressure inlet) which is in reality 3 separte inlets, each oriented in a different direction and not touching. I would like to change this to a velocity inlet, however since the definition of the inlet velocity is cartesian and not magnitude normal to the boundary, I need to split this single patch into three separate patches. Without patchTool is there another way to do this? |
Just a guess but maybe it
Just a guess but maybe it's because the Java3D library (https://java3d.dev.java.net/binary-builds.html) is missing from your Java installation. Try installing the library following the installation instructions in the README on the page. Takuya |
I think I have now fixed my ja
I think I have now fixed my java install. The pathchtool GUI launches, now I just have to work out how to use it.
Thanks for your help. |
