[Other] Problem when trying to generate a new mesh |
June 30, 2006, 07:51 |
Gabriele Ottino
I have a problem when I'm trying to generate a mesh. I created a file blockMeshDict, and then I write the command: blockMesh <root> <case>. This is what is wrote in the shell window: Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 27 Number of boundary faces : 66 Number of defined boundary faces : 66 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Creating merge patch pairs Foam::error::printStack(Foam:stream&) Foam::sigSegv::sigSegvHandler(int) /lib64/tls/libc.so.6 [0x2aaaab9394c0] blockMesh [0x428a3b] __libc_start_main __gxx_personality_v0 I suppose I do an error in creating the file blockMeshDict, but I don't know and I don't understand what kind of error. Could someone help me,please? Thanks a lot. Best regards |
mesh quality problem for displacementSBRStress motion solver | zhaozhenkai | OpenFOAM | 0 | January 22, 2017 11:02 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] Problem with using the Delaunay volume mesh method | manahara | ANSYS Meshing & Geometry | 12 | December 25, 2014 21:54 |
[ICEM] problem of Non-concidence mesh | jeevankumarb | ANSYS Meshing & Geometry | 1 | March 4, 2011 08:47 |
