What is the best option for create a mesh not using blockmesh
I would like to know what is the best option for generate a mesh, without resorting to blockmesh. Is Gambit o.k? I am asking this because FoamX, it seems, does not support the graphical generation of mesh. Is anyone aware of some extensions of OpenFOAM, or FoamX, that can be used. Thanks, Titio |
Hi Titio,
I tried Gmsh, Sa
Hi Titio,
I tried Gmsh, Salome and HyperMesh; good results with all of these, it also seems that Gambit works good. It depends on what you need to do, but I think Gambit is ok, you can experience also the other tool, let me know what you think about them Best Regards Francesco |
I have experience with gambit,
I have experience with gambit, gridgen and gridpro. For complex 3D hex-meshes, you need to put a lot of different blocks in your domain, which is easiest with gridpro and hardest with gambit.....If you've got a simple (2D) comp domain, gambit works just fine.
Regards, Frank |
Other commercial tools are, fo
Other commercial tools are, for example, Tgrid (only volume mesh, you need a good surface mesh), Harpoon or Ansa.
All depends on your specific needs, habits and geometry! Francesco |
I recommened you to use HyperM
I recommened you to use HyperMesh80SR1 with the actual CFD-Update http://www.cfd-online.com/OpenFOAM_D...part/happy.gif of course I do...
You can send me an eMail when you are interested in further information regarding HM Regards, Flo |
