[Technical] mesh generation for a blade section
Old   March 18, 2010, 15:40
Default mesh generation for a blade section
vaina74 is on a distinguished road
My aim is to study the performance of a 'hydro' foil with OpenFOAM (and later of a propeller) and I'm going to create the computational domain with Salome. The Reynolds number is about 1.87E6, so I'll use a turbulent model. I have some questions:
1. is simpleFoam suitable?
2. k-e, k-w or an other turbulent model?
3. if i'm right, k-w doesn't need a wall function. are there any mesh generation guidelines for this model?
4. if i'm right, k-e needs a wall function: how can i evaluate a rough y+ value (and the appropriate distance of the first nodes by the wall) by the Re number?
Thanks for your help.
vaina74 is offline   Reply With Quote
Old   March 19, 2010, 02:05
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Yes simpleFoam works great.
k-wSST model works fine for this type of simulation. k-e realizable also works fine.
Wall functions depends on what type of mesh you are able to generate. If you can create a mesh with a y+ below 1 in the first cell you do not need wall functions and should use a lowRe turb model.
If y+ is above 15 in the first cell you should use wall functions and a high Re model.
I havent come across a method of estimating the first cell thickness based on the overall Re since y+ is very flow driven. I have tried using some estimations but they never end up fitting anyway. I suggest creating an initial coarse mesh and do some iterations, check the y+ value and adjust your mesh accordingly.
Just for inspiration here is a mesh created with Salome with a momentum source (actuator disk) in the middle of the foil.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 19, 2010, 06:29
Thanks for your reply. I generated the domain around my foil, as in the pictures - I can further refine the mesh close to the wall. The blade section is about 300 mm. I think I will first apply the k-wSST model, then I will use different models, as k-e or Low Re.
If I'm right, I can't apply bc with Salome. How can specify patches and apply bc to an imported mesh? Are there any OpenFOAM utilities?
UPDATE
[snappyHexMesh] Snappy Hex Mesh Generation: error preventing the .eMesh file generation. Mariana Garcia OpenFOAM Meshing & Mesh Conversion 1 January 7, 2016 04:24
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
