[snappyHexMesh] weird results with featureEdges |
July 31, 2013, 12:33 |
Rep Power: 13 |
I am using snappyHexMesh and surfaceFeatureEdges extract to mesh a complex pipe with several intets/outlets. My goal is to have first, a good mesh and second, nice surface that can be detected with autoPatch to set up BCs. Unfortunately, the mesh is quite ugly near the featureEdges as you can see on the pictures. I tried to play with the refinement parameters with no success. Any idea on how to improve this ? By the way, is there a way to use these featureEdges to locate BCs instead of using autoPatch ? mesh_forum1.jpgmesh_forum3.jpg mesh_forum2.jpg ----edit----- Modifying de skewness parameters made everything work actually ; however, I'm still stuck with my BCs detection method. Even if I try to optimize the angle, the autoPatch still gives me unwanted results like this : Code:
Feature:55 minCos :0.5735764 Assigned 1 faces to patch auto0 Assigned 892 faces to patch auto1 Assigned 1 faces to patch auto2 Assigned 1 faces to patch auto3 Assigned 69995 faces to patch auto4 Assigned 22 faces to patch auto5 Assigned 300 faces to patch auto6 End Regards, Florian Last edited by Hiroshiman; July 31, 2013 at 14:23. |
Display Modes | |
Weird velocity results for low mach number combustion | Rafael Meier | OpenFOAM Running, Solving & CFD | 0 | June 8, 2018 12:36 |
Save Results automatically by APDL Command | ansyxyz | ANSYS | 1 | June 5, 2018 09:16 |
Mass Fraction F_YI yields weird results | CFDJonas | Fluent UDF and Scheme Programming | 8 | May 9, 2018 10:22 |
very weird results 2d vs 3d simulation of airfoil | dennis722 | STAR-CCM+ | 8 | April 17, 2017 00:15 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 22:36 |
