[blockMesh] generate a graded pipe mesh.
Old   August 22, 2009, 08:58
Default generate a graded pipe mesh.
Jim Enright
jenright is on a distinguished road
I'm trying to generate a 'doughnut' pipe mesh with different levels of refinement at different parts of the pipe using blockMesh.
I want the mesh to be fine in the middle of the pipe and coarse at the inlet and outlet sides.
I create the pipe mesh using a script that allows me to specify the outer and inner radius of the pipe (attached).
I've used the refineHexMesh utility on cells within a bounding box near the centre of the pipe. I also tried snappyHexMesh to refine the region inside a searchable box.
However, both of these seemed to refine in only one direction and the edges from the refined region didn't connect well with the non-refined region. I hope you can see this in the attached screenshot.
Does anyone have any suggestions?
Is it possible to modify my script to get refinement in a specific part of the pipe?
Thanks,
Jim
jenright is offline   Reply With Quote
blockmesh, mesh quality, refinement
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Too diffusive result on Delaunay type mesh for pipe AlmostSurelyRob OpenFOAM Running, Solving & CFD 7 October 8, 2018 13:34
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
