fluent3DMeshToFoam
hi all,
I'm trying to import a mesh that was generated in Gambit(in order to compare OpenFOAM with Fluent),i use the system:OpenSuse10.3,the version:of-1.5. I'm afraid that i have some problem with the convertion of mesh,would you please give me some advice? the step i used ware: 1).i exported a .msh file case from Gambit-2.2,then copied it under the mixerVessel2D of MRFSimpleFOAM folder: 2).ry@linux-pw3p:~/OpenFOAM/ry-1.5/tutorials/MRFSimpleFoam/voim/mixerVessel2D> dos2unix msh/voim2.msh 3).ry@linux-pw3p:~/OpenFOAM/ry-1.5/tutorials/MRFSimpleFoam/voim/mixerVessel2D> fluent3DMeshToFoam msh/voim2.msh but I have the following error message when converting fluent 3d mesh using fluent3DMeshToFoam: Dimension of grid: 3 Number of points: 80727 PointGroup: 1 start: 0 end: 80726. Reading points...done. --> FOAM Warning : Found unknown block of type: "13" --> FOAM Warning : Found unknown block of type: "13" --> FOAM Warning : Found unknown block of type: "13" --> FOAM Warning : Found unknown block of type: "13" --> FOAM Warning : Found unknown block of type: "13" --> FOAM Warning : Found unknown block of type: "13" --> FOAM Warning : Found unknown block of type: "13" Number of cells: 385309 CellGroup: 2 start: 0 end: 278416 type: 1 CellGroup: 3 start: 278417 end: 385308 type: 1 Zone: 2 name: rotor type: fluid. Reading zone data...done. Zone: 3 name: stator type: fluid. Reading zone data...done. Zone: 4 name: wall type: wall. Reading zone data...done. Zone: 5 name: interface.4 type: interface. Reading zone data...done. Zone: 6 name: interface.3 type: interface. Reading zone data...done. Zone: 7 name: pressure_outlet.2 type: pressure-outlet. Reading zone data...done. Zone: 8 name: inlet type: velocity-inlet. Reading zone data...done. Zone: 10 name: default-interior type: interior. Reading zone data...done. FINISHED LEXING --> FOAM Warning : From function boundBox::boundBox(const pointField& points) in file meshes/boundBox/boundBox.C at line 52 Cannot find bounding box for zero sized pointField, returning zero Creating cellZone 0 name: fluid type: fluid #0 Foam::error::printStack(Foam:stream&) in "/home/ry/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/ry/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::polyTopoChange::getFaceOrder(int, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&) const in "/home/ry/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so" #4 Foam::olyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&) in "/home/ry/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so" ... #7 main in "/home/ry/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/fluent3DMeshToFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 __gxx_personality_v0 in "/home/ry/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/fluent3DMeshToFoam" 段错误 what can i do ? thanks in advance! regards, jennifer |
Hi Jennifer,
You don't need to 'dos2unix' the mesh file. Just use 'fluentMeshToFoam' on the mesh file exported from Gambit. Hope it helps, Philip |
Jennifer,
There must be a difference between 'fluentMeshToFoam' and 'fluent3DMeshToFoam', but I don't know what it is. I usually use 'fluentMeshToFoam' and it works fine for 3D geometry, or I use 'gambitToFoam'. 'gambitToFoam' takes a Gambit neutral mesh type '.neu' and converts it to OpenFOAM, so that works too. But you must define your boundary patches in Gambit prior to exporting, then you can change their type once they are in OpenFOAM in the './constant/polyMesh/boundary' file. Philip |
hi vishal,
thank you for your reply,and i have resoled the problem. and i still thank you very much. the problem is my error mesh file,after i changed it .and it works OK! |
Hello guys,
I have very simple question. I dont know how to convert the values for the mesh to meter after importing from fluent. as far as i know, for the mesh which is created by OF, we have to do it in blockmeshdic. but how can we convert it to meter or.. when we import the mesh from fluent??? Thanks, Mehran Quote:
Mehran,
The mesh can be scaled when converting with fluentMeshToFoam using the scale option. ie fluentMeshToFoam YOURMESH.msh -scale 1000 where 1000 is the scaling factor in this example, and YOURMESH.msh is your mesh. Or if you already have your mesh in OpenFOAM, the transformPoints command can be used to scale the mesh: transformPoints -scale "(1000 1000 1000)" this command allows the mesh to be scaled differently in the x, y and z directions. Hope it helps, Philip C |
you just input"transformPoints -scale "(0.001 0.001 0.001)""under your root case,then you can see the value which in the file boudary/polymesh/sets/points convert into meter Good luck jennifer |
Thanks Philip &Jennifer
i am trying to convert a mesh using following and i am facing following error fo both Fluent3DMeshToFoam and FluentMeshToFoam do some know what can be the remidy......!!! transsolar@linux-u5tz:~/OpenFOAM/run/meshFiles/cavity> fluent3DMeshToFoam WK_Modell_Konf_mit_Hochhaus_endg_Druckbohrungen_me shed_1-05~3.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-53b7f692aa41 Exec : fluent3DMeshToFoam WK_Modell_Konf_mit_Hochhaus_endg_Druckbohrungen_me shed_1-05~3.msh Date : Jul 29 2010 Time : 11:28:44 Host : linux-u5tz PID : 4493 Case : /home/transsolar/OpenFOAM/run/meshFiles/cavity nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Header: "TGrid 3D 5.0.6" Dimension of grid: 3 Number of points: 1907883 Number of faces: 9120079 Number of cells: 3616970 --> FOAM Warning : Found unknown block of type: "3010" on line 9 Do not understand characters: on line 10 From function fluentMeshToFoam::lexer in file fluent3DMeshToFoam.L at line 747. FOAM exiting transsolar@linux-u5tz:~/OpenFOAM/run/meshFiles/cavity> ================================================== ============== transsolar@linux-u5tz:~/OpenFOAM/run/meshFiles/cavity> fluentMeshToFoam WK_Modell_Konf_mit_Hochhaus_endg_Druckbohrungen_me shed_1-05~3.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-53b7f692aa41 Exec : fluentMeshToFoam WK_Modell_Konf_mit_Hochhaus_endg_Druckbohrungen_me shed_1-05~3.msh Date : Jul 29 2010 Time : 11:31:31 Host : linux-u5tz PID : 4517 Case : /home/transsolar/OpenFOAM/run/meshFiles/cavity nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading header: "TGrid 3D 5.0.6" Found unknown block:(4 Embedded blocks in comment or unknown: ( Found end of section in unknown:) Found end of section in unknown:) Dimension of grid: 3 Number of points: 1907883 number of faces: 9120079 Number of cells: 3616970 Found unknown block:(3010 Embedded blocks in comment or unknown: ( Found end of section in unknown:) Embedded blocks in comment or unknown: ( ���Embedded blocks in comment or unknown:( �@�ۆ�Embedded blocks in comment or unknown:@� Found end of section in unknown:� �����@��@��▒Embedded blocks in comment or unknown:@� ���,@�}��@]��Found end of section in unknown:� (�+� @��Embedded blocks in comment or unknown:�� Embedded blocks in comment or unknown:�� ��Found end of section in unknown:$ ,@Embedded blocks in comment or unknown:�� Found end of section in unknown:� @��@Embedded blocks in comment or unknown:� Illegal hex digit: '�' file: IStringStream.sourceFile at line 0. From function readHexLabel(ISstream&) in file db/IOstreams/Sstreams/readHexLabel.C at line 54. FOAM exiting please help me in this regard......... thanks in advance |
Hi Vishal,
Was your ".msh" file created in fluent/gambit? I notice Quote:
hence fluentMeshToFoam will not work. If your mesh was created in TGrid, then maybe TGrid can export as a fluent mesh or a gambit mesh, I have not used TGrid so I don't know. Best Regards, Philip |
You should use file -> write case in TGrid and check "Save as Polyhedra" and uncheck "save as binary" so you will get a ASCII msh-File (even though it might have the ending .cas) with polyhedral cells. This will work with fluent3DMeshToFoam. I guess you did not save it in ASCII format. Regards Bastian |
Philip |
Thanks,
for your valuable inputs......!!! @Bastil and Bigphil: - It worked as bastil told....!!! |
