Gmsh units?
Hi guys,
can you tell me which units gmsh is using? I couldn't find any information about this...:confused: Would be nice if I could tell gmsh to set mm as default unit... Thanks, Ben |
Dimensionless or Meters
I believe its units are non-dimensional and depend on what your solver loads it as. For the sake of dimensional sanity, I believe most every solver uses meters. I always just use meters from the beginning, but there are some utilities to help scale your already present numbers.
For scaling inside of gmsh: (have not used) Dilate { { expression-list }, expression } { transform-list } In OpenFOAM you might look into transformPoints(have not used) http://www.cfd-online.com/Forums/openfoam-meshing-gmsh/61881-gmshtofoam-gmsh2tofoam-amp-gmsh-sudden-disappear.html#post204111 In OpenFOAM's blockmesh the convertToMeters function will preform scaling. Hope that helps! |
Just in case someone runs into the same problem: The Gmsh-default unit seems to be meters. I found two ways solving my problem to change this default-unit for usage with OpenFoam:
First option uses the Gmsh default-settings. Create your geometry, mesh everything and save the mesh. Import that mesh into your foam-case by Code:
gmshToFoam <name.msh> Code:
transformPoints Code:
# cd $TO_YOUR_FOAM_CASE Code:
Mesh.ScalingFactor=0.001 Hope that helps. |
[Gmsh] Gmsh units?Reply to Thread
Hi !
I always thought I was alone responsable for choosing a coherent set of units : USI for example :cool: |
