archymedes |
March 31, 2010 07:23 |
Fluent Mesh (XP32) to OpenFoam
Hello!
I am new with OF and have just run some tutorial examples up to now. Recently I wanted to start my own simulations and compare them to ansys results.
I have created a model geometry and Mesh in Ansys Worbench 12 ( where Fluent is included) on a WinXp32 machine and exported a .msh file from fluent. In the Fluent launcher I've added the environment Variable
AWP_WRITE_FLUENT_MESH_ASCII=1
Restarting the machine on Ubuntu i execute
$dos2unix -b myMesh.msh
When I compare the converted file and the backup in GEDIT it looks exactly the same (is that the way it should be even after the conversion ?).
Then I've tried to convert the Mesh with fluentMeshToFoam , because it's a 2D Mesh
$ fluentMeshToFoam quader2_envVarFluent.msh
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-53b7f692aa41
Exec : fluentMeshToFoam quader2_envVarFluent.msh
Date : Mar 31 2010
Time : 12:08:40
Host : BE13661
PID : 2337
Case : /media/System/Claus/GasSimu/OpenFoam/valve_All_2D
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
number of faces: 402
Number of points: 56
Reading uniform faces
Reading points
FINISHED LEXING
#0 Foam::error::printStack(Foam::Ostream&) in "/home/claus/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/claus/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 main in "/home/claus/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/fluentMeshToFoam"
#4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#5 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Segmentation fault
being curious I' also tried fluent3DMeshToFoam which gave me
$ fluent3DMeshToFoam quader3D_EnvVarFluent.msh
Exec : fluent3DMeshToFoam quader3D_EnvVarFluent.msh
Date : Mar 31 2010
Time : 12:18:25
Host : BE13661
PID : 2370
nProcs : 1
Create time
Number of faces: 5616
Number of points: 866
FaceGroup: 5 start: 4752 end: 4895. Reading uniform faces...done.
FaceGroup: 6 start: 4896 end: 5039. Reading uniform faces...done.
FaceGroup: 7 start: 5040 end: 5615. Reading uniform faces...done.
PointGroup: 1 start: 0 end: 865. Reading points...done.
FINISHED LEXING
Mesh is not 3D, dimension of grid: 0
From function fluent3DMeshToFoam
in file fluent3DMeshToFoam.L at line 824.
FOAM exiting
So the conversion routine recognizes the wrong dimension that is to say 0 instead of 2D.
Does anyone have an idea what could be wrong ? How to check if the ASCII export was done properly ?
The file is on a windows ntfs partition which I access from ubuntu which was installed on another partition.
Thank you for your help!
