[Other] OpenFOAM - structured or unstructured Grids ? |
April 29, 2010, 03:15 |
Hi everybody,
For a change, I have a more general question to the community: I have been using OpenFOAM now for about 1 year and we were running in massive trouble using unstructured grids (non isothermal). We have heard now that most applications are actually on structured grids and that OF actually in reality needs structured grids. Can you confirm that? Isn't there anybody who runs complex geometries on unstructured grids? For us this would mean that we need to think about the use of an improved snappyHexMesher. Thanks a lot to you all, Thomas |
April 30, 2010, 02:24 |
#2 | ||
Mark Olesen
Rep Power: 40 |
Of course, a tet mesh may still give you problems. Quote:
Do the geometries pictured on page 20 of the following document qualify? http://www.opensourcecfd.com/conference2009/proceedings/documents/Session%20III/OSCIC2009_Hinterberger.pdf |
April 30, 2010, 11:39 |
#3 | ||
Alberto Passalacqua
Rep Power: 36 |
OpenFOAM is, in my experience, quite sensitive to the mesh quality, so you need to be a bit careful when generating the grid to avoid very skewed cells. Many of the users I saw reporting problems were using salomé or gmsh to generate their grid. They're good tools, but, in my experience, their meshing capabilities are not always the best for finite-volume codes. Quote:
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
May 3, 2010, 05:06 |
Yes, we saw that there was some discussion about problems with tetras, we are using the commercial mesher Centaur to generate the mesh and have some problems in particular with high aspect ratio cells...
We have also seen that OF can handle polyheder meshes, however the background of my question was that we heard that most industry projects with OF generally use an improved snappyHexMesher to generate robust meshes since OF is so sensitive to mesh quality. @Mark, yes on page 20, those would be complex geometries. I guess the iteration process to generate a good, unstructured OF mesh will just take a little bit longer... |
May 3, 2010, 07:14 |
For unstructured meshes with high skewness, I've seen that choice of schemes is quite important. I might recommend fvScheme settings (for simpleFoam with kOmegaSST_lowRe) such as:
//************************************************** ****** ddtSchemes { default steadyState; } gradSchemes { default cellLimited leastSquares 1.0; } divSchemes { default none; div(phi,U) Gauss reconCentral cellLimited leastSquares 1.0; div(phi,k) Gauss vanLeerDC; div(phi,omega) Gauss vanLeerDC; div(R) Gauss linear; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear limited 0.5; laplacian((1|A(U)),p) Gauss linear limited 0.5; laplacian(DkEff,k) Gauss linear limited 0.5; laplacian(DomegaEff,omega) Gauss linear limited 0.5; laplacian(1,p) Gauss linear corrected; } interpolationSchemes { default reconCentral phi leastSquares; interpolate(U) reconCentral phi leastSquares; } snGradSchemes { default limited 0.5; } fluxRequired { default no; p ; } //************************************************** ****** FYI: you will need to use 1.5-dev with these settings (reconCentral doesn't exist in 1.6.x). |
July 1, 2010, 05:45 |
Ramnik Singh
Hellp epg,
Can u please suggest similar schemes for unstructured mesh for openFoam1.6x. Thanks in Advance Ramnik |
July 1, 2010, 05:51 |
Ramnik,
If you want advanced functionality such as the reconCentral scheme, I would advise that you use the OpenFOAM-extend version. There is significant capability there that doesn't exist in 1.6.x or 1.7. |
July 1, 2010, 06:18 |
#8 | |
Ramnik Singh
Egp,
Changing the version is not possible as i am required to show my results for 1.6. I am running a 3D simulation for an emptying process of a surge tank design using interfoam. I have an unstructured grid and i have been facing this problem for a very long time now. The Courant's number jumps to a very high value suddenly. the mesh check is completely ok except around 230 non-orthogonal faces. here is the error Quote:
residual2.jpg Can u please have a look and suggest solution Regards Ramnik |
July 1, 2010, 12:38 |
Alberto Passalacqua
Rep Power: 36 |
Could you publish your fvScheme and fvSolution dictionaries?
Best,
July 1, 2010, 12:40 |
#10 | |
Alberto Passalacqua
Rep Power: 36 |
Thanks,
July 1, 2010, 14:02 |
#11 |
Alberto Passalacqua
Rep Power: 36 |
I answered myself, and compiled it for 1.7.x. You find it attached (wmake libso to build it, and then include it in controlDict), but I doubt this will fix the problems you are facing, so it would still be useful to see your numerical setup.
Best,
July 2, 2010, 18:39 |
#12 |
BastiL
Rep Power: 20 |
July 2, 2010, 19:38 |
#13 | |
Alberto Passalacqua
Rep Power: 36 |
vanLeerDC is the vanLeer scheme with deferred correction. I never used them in OF since they're not in the 1.7.x, but I am a bit doubtful about the improvements they can bring on poor meshes. Sometime it is just easier to fix the mesh than waste time fiddling with schemes. You'll also gain in quality of the results. Best,
July 3, 2010, 05:11 |
#14 |
BastiL
Rep Power: 20 |
Thanks Alberto. So it is a modification of "linear" in terms that it still is cental differencing and second order?
April 27, 2012, 08:00 |
#15 |
ms
Well, I'm interested in the reconCentral approach now, too. My openFoam is version 2.1.0 and I downloaded it for Ubuntu without building it. My questions are....
1) Is openFoam-ext still going? The website shows little / no forum activity that I could see. 2) Can I insert components from openFoam-ext into openFoam 2.1.0, given that I didn't build it? 3) Do openFoam-ext components find their way into openFoam after time or is it completely separate? (This seems a little odd, given the open/free nature of the code). Best regards all, Mark. |
April 27, 2012, 11:07 |
#16 | ||||
Alberto Passalacqua
Rep Power: 36 |
Best,
October 16, 2012, 14:59 |
#17 | |
andres
Thanks! Andrés |
April 5, 2013, 06:18 |
#18 | |
sirshosona
October 10, 2014, 06:31 |
fv-schemes- unstructured- no extended ?
#19 |
Tobias Adam
Rep Power: 12 |
Hello everyone
What settings for unstructured Mesh do you prefer for people who don´t use the extended version of OpenFoam? Greets Tobi |
March 13, 2017, 06:03 |
#20 |
Bharadwaj Bhushan
Rep Power: 9 |
hi Alberto,
can you suggest me which meshing tool is best suited for openFoam ? Thank you |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
Convert mesh from unstructured Openfoam to structured | ayushmorx | Mesh Generation & Pre-Processing | 0 | October 10, 2017 11:24 |
Structured and Unstructured mesh | Jingwei | FLUENT | 0 | March 2, 2009 21:29 |
Structured versus unstructured grids | Siobhan O'Callaghan | FLUENT | 0 | April 9, 2002 09:25 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
