[blockMesh] blockMesh error
Old   May 11, 2010, 14:17
Default blockMesh error
Giancarlo
Giancarlo is on a distinguished road
Hello everyone,
I'm trying to install OpenFoam 1.6 on Ubuntu 9.10 64 Bit.
I've followed the canonical procedure to install it...
I was put to the task of testing out the install and tried to do the first tutorial, Lid-Driven Cavity Flow. For whatever reason, when I run the command blockMesh (yes, I've made sure that I type it in as blockMesh), I get "-bash: blockMesh: command not found."
I don't really have a clue as to what is going on with it (other than that it either wasn't made or isn't linked correctly): any help would be appreciated.
Thanks a lot,
Giancarlo
Giancarlo is offline   Reply With Quote
Old   May 13, 2010, 07:32
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Did you add the appropriate lines to your .bashrc file?
http://www.openfoam.com/docs/README.php
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 13, 2010, 09:16
Unhappy
Giancarlo
Yes.. I've already done it...
Old   May 13, 2010, 09:20
sega's Avatar
Sebastian Gatzka
Strange ...
Did you even source the .bashrc afterwards (restart the terminal)?
Any messages when opening a new terminal?
Old   May 13, 2010, 12:03
Giancarlo
Yes, I've source .bashrc..
Anyway when I've test the Installation it has found a CRITICAL ERROR :
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/limin/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
