[Commercial meshers] having problems with fluent3DMeshToFoam
Old   May 7, 2010, 07:29
Default having problems with fluent3DMeshToFoam
stevek is on a distinguished road
Hello all,
I have a *.msh file I would like to convert to OpenFOAM format. My *.msh file contains hanging nodes, however I found one post on this forum which indicated fluent3DMeshToFoam could handle this. My intent is to use zipUpMesh utility after the conversion to remove the hanging nodes. Running the converter gives the following error:
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-605bfc578b21
Exec : fluent3DMeshToFoam gaussian.msh
Date : May 07 2010
Time : 13:03:32
Host : dkrdscfdst01
PID : 5137
Case : /cfd/grsox/openFoam/level1/gibraltar
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Dimension of grid: 3
Number of points: 1740936
PointGroup: 1 start: 0 end: 1740935. Reading points...
--> FOAM FATAL ERROR:
index 1740936 out of range 0 ... 1740935
From function UList<T>::checkIndex(const label)
in file /home/grsox/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/UListI.H at line 110.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/grsox/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/grsox/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/errorManip.H:87
#3 Foam::UList<Foam::Vector<double> >::checkIndex(int) const at ~/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/UListI.H:114
#4 Foam::UList<Foam::Vector<double> >:perator[](int) at ~/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/UListI.H:141
#5 yyFlexLexer::yylex() at ~/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/mesh/conversion/fluent3DMeshToFoam/fluent3DMeshToFoam.L:372
#6 main at ~/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/mesh/conversion/fluent3DMeshToFoam/fluent3DMeshToFoam.L:816
#7 __libc_start_main in "/lib64/libc.so.6"
#8 __gxx_personality_v0 in "/home/grsox/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/fluent3DMeshToFoam"
Aborted
Is it true that fluent3DMeshToFoam can take hanging nodes or is my approach of this utility + zipUpMesh rubbish?
Thanks in advance,
Steve
stevek is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
