[surface handling] Subdivision of faceZone or baffle
Old   August 14, 2019, 08:23
Default Subdivision of faceZone or baffle
hyn
hyn is on a distinguished road
I am trying to divide a faceZone (which I use as a baffle) into several smaller ones. That way, I plan to be able to specify slightly different boundary conditions for each of them.
I was not able to find anything to achieve this (other than manually splitting it). The goal is to have a high number of divisions, requiring some kind of algorithm to generate them. Even going to a 1 face per baffle would be ok.
Is something like this possible? Thanks
hyn is offline   Reply With Quote
Old   August 23, 2019, 06:37
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
You can use topoSetDict to split single faceZone into multiple faceZones. But it is also kind of manual as you have to write the coordinates of each vew faceZone.
Regards
mwaqas is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
Problems using createBaffles to create a 3D thermal baffle zfaraday OpenFOAM Running, Solving & CFD 10 September 6, 2017 17:07
[snappyHexMesh] handling of baffle regions or surfaces with zero thickness with snappyHexMesh StSchiff OpenFOAM Meshing & Mesh Conversion 5 March 8, 2017 09:45
Calculate Mass Flowrate at a faceZone with OpenFOAM4 donQi OpenFOAM Post-Processing 1 August 31, 2016 21:13
