Problems meshing a pipe
Dear Foamers,
I want to mesh a pipe-system with snappyHexMesh. The best way to do it seems to be: 3 stl-Files one for the pipe, one for the inlet and one for outlet. Right? But i don't get it right. Can you tell me, how the geometries behind this stl-Files have to look like? Can i define just areas for Inlet and Outlet and the wall of the pipe (my CAD-programm (Inventor Prof.2011) says: no, a geometry has to be a volume-body to export it as *.stl)? I am still a beginner in OpenFoam and so thankfull for every help and hint you can give, concerning simulating internal flow problems. greets U. |
Hi Ulrich,
Specifying 3 stl files is how I have looked at similar problems in the past. I normally export my geometries from SolidWorks and I am able to export stl files for both the entire 3D geometry and for selected surfaces. In SolidWorks I can select a surface from the 3D part and then select save as an STL file and it will ask if I want to save just the surface or everything. Selecting just the surface is what I choose to get an stl file for each boundary. I am not familiar with Inventor Prof 2011, but have you tried doing something similar? The basic format of an STL files is discussed at http://en.wikipedia.org/wiki/STL_(file_format) I hope this helps somewhat. Cheers, Paul. |
Hello Paul,
thank you for your help. As far as i know, until now, Inventor cannot export just a surface in a stl-File. But it is not a problem anymore, for me. In the end my biggest mistake in this case was something other: Open Foam is in meter and my inventor-stl-file was in mm. A slight mistake. :) Thanks and greets U |
