[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder |
March 10, 2011, 13:32 |
Diauddin Nammari
Good evening Foamers,
I was wondering if anyone could help, I am trying to model a tank in simple domain. I am trying to analyse the recirculations zones inside the cylinder and outside. So far it has been straight forwards to create a solid cylinder, but creating a hollow cylinder using snappyhexmesh seems a wee bit tricky, I haven't managed so far, does anyone have any ideas ? Much appreciated Dia |
March 11, 2011, 07:25 |
Hi Dia,
Maybe, you can give more details about your geometry, like is the inside domain connected with the outside domain? It also would help to make clear, which procedure you are using. Regards, fritz |
March 11, 2011, 09:46 |
Diauddin Nammari
Hi Fritz,
Thanks for answering back, that is what I want indeed that the inside domain is connected to the outside domain. Such that I would allow the "wind" to wizz inside the the tank( storage tank) and outside it. If you don't mind what do you mean by procedure ? I am planning to test out a few solvers, and play around with windfoam. As you can get I am trying to avoid "creating" the blockMesh dict by hand, or trying to use other software to create the geometry. Cheers Dia |
March 11, 2011, 10:48 |
#4 | |
Besides, what exactly is the problem? |
March 11, 2011, 14:10 |
Diauddin Nammari
I was trying to create a hollow cylinder with the opening into the domain. So far the cylinders or objects I create are closed. That is my issue. Not how to do that.
Cheers Dia |
March 11, 2011, 19:49 |
Then, I don't understand your problem. It's absolutely the same.
hollowcylinder |
[snappyHexMesh] Problems with scaling meshes when meshing with SnappyHexmesh | Bnitter | OpenFOAM Meshing & Mesh Conversion | 1 | November 15, 2018 08:26 |
[Gmsh] 3D Free surface flow past circular cylinder meshing using GMSH | arieljeds | OpenFOAM Meshing & Mesh Conversion | 7 | January 14, 2017 12:57 |
[snappyHexMesh] Inside and outside mesh with snappyhexmesh | nzy102 | OpenFOAM Meshing & Mesh Conversion | 21 | February 16, 2016 16:42 |
simulation of piston motion inside a hydraulic cylinder | mosman | FLUENT | 0 | August 6, 2011 15:44 |
2D planar cylinder meshing problem | saisanthoshm88 | ANSYS Meshing & Geometry | 15 | December 27, 2010 11:14 |
