[snappyHexMesh] Defining separate objects as a region in an STL file at once |
September 29, 2023, 01:36 |
george
Rep Power: 5 |
I'm seeking a way to define regions for multiple bodies within a single STL file simultaneously. When I mesh geometries like the one shown in fig-1 using snappyHexMesh, I encounter difficulties in defining inner coordinates (locationsInMesh). When there are a large number of objects (more than 100) that need to be defined, manually writing coordinates becomes frustrating because I have to identify the inner coordinates for each separate object in the STL file before adding them to the snappy dictionary. When I provide only one coordinate, it creates a region exclusively for that specific object or part. Code:
locationsInMesh ( ((x0 y0 z0) fluid_region) //--------------------------// (( x1 y1 z1) solid_region_1) . . (( xn yn zn) solid_region_1) //--------------------------// (( x1 y1 z1) solid_region_2) . . (( xn yn zn) solid_region_2) ); regards, scfd |
September 29, 2023, 03:34 |
M
Rep Power: 12 |
AFAIK there is no possibility to just mesh every region. That would be a great feature, though.
seperate, snappyhexmesh, stl |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
