searchableBox at an angle?
Is it possible to define a type searchableBox with an angle?
I want to specify a region for a rectangular area that is not parallel to the yz plane. Thank you |
Bump
Did you find a solution back in 2011, Want the same thing.
- Fridrik Magnusson |
Nope :/ i found a workaround, drew it in a CAD program, where it should be, then exported it as an *.stl - Then it had it shape and rotation.
I saw your another post about editing snappyHexMeshDict with coordinateRotation. I am trying to figure out a solution in this direction. Any suggestion from your experience? |
