Home > Forums > OpenFOAM Meshing & Mesh Conversion
Failed 1 mesh check
Like Tree19Likes
Old   May 23, 2013, 06:20
Andreas Wendy
A.Wendy is on a distinguished road
hi,
are all of this patches defined in the 0-folder?
topAndBottom 440 884 ok (non-closed singly connected)
inlet 120 242 ok (non-closed singly connected)
outlet 120 242 ok (non-closed singly connected)
front 51101 52012 ok (non-closed singly connected)
back 51101 52012 ok (non-closed singly connected)
airfoil_airfoil 5168 5491 ok (non-closed singly connected)
best wishes
Andreas
A.Wendy is offline   Reply With Quote
Old   May 24, 2013, 08:37
faraz
faraz22 is on a distinguished road
Originally Posted by s.m View Post
Hi,faraz
i didn't get what do you mean sorry.
i put my blockMeshDict and the checkMesh files in the following, would you please tell me again.
thank you very much.
Hello S.m please try to upload some pictures of your background mesh here .. ill see. actually the faces your have mentioned in blockmesh are those which you need for your case. but in order to avoid the given error , you always have to define all the remaining faces of sketch or drawing in blockmesh ... no matter your need those faces or not. may you get it?
s.m likes this.
faraz22 is offline   Reply With Quote
Old   May 25, 2013, 02:59
s.m
saeideh mohamadi
s.m is on a distinguished road
Hi faraz,
i put a screenshot of my mesh with it's patch name. my background mesh is a domain with inlet outlet top and bottom after running the snappyHexMesh i 'll have this mesh that i upload here.
i put my block mesh also, i want to know what should i add to my blockMeshDict ?
airfoil_airfoil?
s.m is offline   Reply With Quote
Old   May 26, 2013, 12:30
s.m
saeideh mohamadi
Hi faraz,
i understand what should i do, thank you very much for your explanation.
Best Regards.
faraz22 likes this.
Old   September 18, 2013, 03:42
Baek, Donghae
wes1204 is on a distinguished road
http://www.tfd.chalmers.se/~hani/kur...eTutorials.pdf
you can get the solution from 77page on this document.
just refer it.
wes1204 is offline   Reply With Quote
Old   April 14, 2017, 07:42
sarath krishnan
sk11 is on a distinguished road
Thanks wyldkat! extruding solved my problem!
sk11 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
mesh check failed / degenerated contact points shohin FLUENT 16 April 11, 2014 22:32
ParaView/Parafoam error when making animation Disco_Caine OpenFOAM Paraview & paraFoam 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 10:58
