[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh
Old   June 30, 2009, 16:15
Default Pipe flow / Internal fluid dynamics with SnappyHexMesh
Fabian Denner
denner is on a distinguished road
Hi guys,
I like to apply SnappyHexMesh to a pipe-like flow, respectively to internal fluid dynamics. I read the manual and struggle with the following statement:
"The objective is to mesh a rectangular shaped region (shaded grey in the figure) surrounding an object described by and STL surface, e.g. typical for an external aerodynamics simulation."
Isn't it possible to apply SnappyHexMesh to internal flow? Does anybody have experience with this topic?
Cheers,
Fabian
denner is offline   Reply With Quote
Old   July 21, 2009, 05:43
Gecko is on a distinguished road
It certainly is possible to mesh interior regions, it is just that the instructions are written with only a single application in mind. It all depends on where you put the internal point in the dictionary file.
Gecko is offline   Reply With Quote
Old   October 10, 2011, 10:43
Marco Turchi
zebu83 is on a distinguished road
Originally Posted by denner View Post
Hi guys,
Cheers,
Fabian
Hi Fabian,
have you run your case?
I'm able to run external aerodynamics simulation, but I don't understand yet how to run internal simulations.
I think, like Gecko wrote, I have to put right internal point in the dictionary file, but I don't understand how.
Thank you in advance for your help.
Best regard
MT
zebu83 is offline   Reply With Quote
Old   October 13, 2011, 09:24
Elia Agnani
elia87 is on a distinguished road
Send a message via Skype™ to elia87
Hi Marco,
for mesh the internal region of your .stl geometry you just have to change the coordinates of the LocationInMesh point in the sHMDict file
 // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (15 0 0); <-- here you must enter a point that is internal to your geometry
Obviously you must have previously defined the reference geometry with blockMesh as it is written on the tutorial.
Good luck
Let me know if it worked
elia87 is offline   Reply With Quote
pimpleFOAM - internal pipe flow - convergence gu1 OpenFOAM Running, Solving & CFD 0 December 18, 2017 13:24
3D fluid flow with internal face cecastroc OpenFOAM 0 May 9, 2017 21:26
internal pipe flow Amar Kad CFX 0 January 23, 2016 00:46
fluid flow around a half burn pipe Destry FLUENT 13 July 16, 2010 21:42
Bulk mean fluid temperature in internal flow mssound FLUENT 0 May 13, 2010 15:56
