[CGNS] foamToCGNS converter got Error: wrong number of vertices in cell |
March 1, 2012, 18:19 |
Aqua
Rep Power: 14 |
Dear all,
I created my mesh in OF1.6ext by snappyHexMesh, Then try to convert it into cgns by foamToCGNS in OF1.5-dev. Then error showed up as follows: Wrong number of vertices in cell expected 4,5,6, or 8, found 0 From function foamToCGNS in file writeCGNS.H at line 219. Could anyone help on this? Thank you so much! Aqua |
March 1, 2012, 18:58 |
Aqua
Rep Power: 14 |
Please, can anyone tell me, CGNS converter doesn't work with snappyHexMesh?
Thank you so much!! Aqua |
March 1, 2012, 19:00 |
Aqua
Rep Power: 14 |
It's me again:
Just found some information from the forum in 2008 as follows: "As of now, the cgnsToFoam converter only supports the following type of 3D cells for unstructured mesh: tetrahedron (TETRA_4) pyramids (PYRA_5) prisms (PENTA_6) hexahedron (HEXA_8) " that means, before 2008, it can not handle SHM, but how about now? is there some new version? Thank you! aqua |
Display Modes | |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 10:12 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
