[Gmsh] Unable to Convert .stp to .msh file FOAM FATAL IO ERROR |
March 1, 2012, 14:55 |
Brandon Lien
Hi, i have been trying to get my .stp to .msh. And somewhere in here I am messing up as when i run gmshToFoam I keep getting errors. The most recent being.
--> FOAM FATAL IO ERROR: No cells read from file "testmodel" Does your file specify any 3D elements (hex=5, prism=6, pyramid=7, tet=4)? Perhaps you have not exported the 3D elements? As far as steps I have taken, I have basically just opened gmsh, Merge, grabbing my .stp file. Then used the 3D, and then 3D optimizing(netgen). Saving that as a .msh and trying the gmshToFoam where i receive the above error. I tried to attach the .stp file, but it exceeds the forum limit. If you need/want this I can email it. Thanks |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
