snappyHexMesh for porous - multiple regions without boundaries
Hi
I am using sHM for porousSimpleFoam As a starting point I used snappyMultiRegionHeater with 2 stl files as input without splitting the mesh The problem is that sHM defines a boundary between the porous zone and the non-porous zone - when I remove the (wall) boundary from constant/polyMesh/boundary I can run the the application How can I run sHM with two regions seperated by a stl surface without getting a boundary between the regions? (If there is a better way I would be happy to know ;) Thanks in advance Per |
