paraview : how to save a "selection over time" graph ?
Hi!
I am carried out a calculation over a 3D vertical tube. I know how to plot the average value of a field (pressure for example) at a region of the tube with "plot selection over time". How can I save this curve into a text file ?? Best regards, Cyp |
I finally found the solution :
- select the region - "extract by region" - "integrate variable" - select the variable you want to plot in the intragrate variables table - "plot selection over time" - in the object inspector panel, click on "information", then select the data array you want to save in a text file (p or U for example) - Then, file>save data. @+ Cyp |
Hello Cyp,
I am also trying to plot graph of mass (kg) over time but i have mass fraction results. I want to see the total mass injected in the full domain. Is there any way to check that on paraView and then plot over time? Regards, Umer |
