[OpenFOAM] Converting an XML colour scale to a list for RGBPoints in pvbatch |
November 19, 2012, 04:16 |
Joe Borg
In the ParaView GUI, this is easy, you just click "Edit color map" -> "Choose preset" -> "Import", select the xml file and you're away. I can't seem to be able to do this in batch though. Is there any way I can?
colormap, paraview, xml |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
CFD post cannot load results-Error appeared? | mariam.sara | ANSYS | 9 | September 17, 2018 15:23 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
