[OpenFOAM] View Refinemet Regions in Paraview |
November 30, 2012, 15:16 |
Hello Everyone,
Is it possible to view the refinement regions in paraview without viewing the mesh? My goal is to simply see my .stl file with the corresponding refinement regions. Thank you! |
December 2, 2012, 06:58 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings stark22,
I'm not certain of what you're asking... what exactly do you want to see? Is it:
Bruno
December 3, 2012, 09:34 |
Bruno,
Thank you for the response. I'm looking for a wire frame view of the refinement regions with respect to the imported geometry. So what I would like to see is the imported STL file along with the refinement boxes that I have created. Also, if it's not to much trouble I'm interested in options 2 and 3 if you would care to elaborate. Thank you. |
December 3, 2012, 16:56 |
Bruno Santos
Rep Power: 128 |
Hi stark22,
Attached is the basis for most of the examples.
As for mapping the values onto the STL surface, you can use the filter "Resample with Dataset". Keep in mind that this filter requires both a "Source" and an "Input"... which I always confuse the two, so you better do some trial-and-error. Last but not least, you've also got the filter "Extract Cells By Region", which might come in handy. Best regards, Bruno
[OpenFOAM] Paraview 3.98.0 does not update list of mesh regions | letzel | ParaView | 6 | April 19, 2021 15:57 |
[OpenFOAM] How to view openfoam results in paraview | Marineboy | ParaView | 9 | June 19, 2019 21:16 |
[General] Paraview nice animation | PyGloo | ParaView | 4 | June 7, 2012 12:34 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
Paraview not found | fusij | OpenFOAM Installation | 2 | January 1, 2011 20:44 |
