Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Post processing problem in Xfce desktop environment using paraFoam
Old   June 24, 2013, 10:56
Unhappy Post processing problem in Xfce desktop environment using paraFoam
tariq
tariq is on a distinguished road
I have been facing problem in post-processing using paraFoam. While doing the simple cavity tutorial (http://www.openfoam.org/download/ubuntu.php), after putting the paraFoam command these lines appears in the Terminal:
created temporary 'cavity.OpenFOAM'
/sw/openfoam/ThirdParty-2.2.0/platforms/linux64Gcc46/paraview-3.12.0/lib/paraview-3.12/paraview: error while loading shared libraries: libQtHelp.so.4: cannot open shared object file: No such file or directory
What's the error here? As I'm new in Ubuntu and openFoam, have no idea about these typo errors!!
the operating system is Xfce desktop environment https://en.wikipedia.org/wiki/Xfce
Can anyone please help me out...
https://tariqridwan.github.io/
tariq is offline   Reply With Quote
Old   June 24, 2013, 13:53
Nima Samkhaniani
nimasam is on a distinguished road
try to install libQtHelp.so.4 , maybe you can use following command in terminal:
sudo apt-get install libqt4-help
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   July 2, 2013, 10:43
tariq
Originally Posted by tunkers View Post
I also had the same problem with openfoam 1.7 when installing on Debian Lenny
paraview would run fine when launched manually, but not from paraFoam.
/home/cfduser/OpenFOAM/OpenFOAM-1.7/bin/paraFoam: 132: paraview: not found
to fix this, edit the following file
/home/cfduser/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc
add this line near somewhere near the top
export PATH=$PATH:/home/cfduser/OpenFOAM/ParaView-3.8.0-Linux-i686/bin
then
$cd
$. .bashrc
Now you will be able to type paraview from anywhere and it will run. Also paraFoam will also be able to launch paraview.
I'm also facing the same problem
after doing blockMesh & icoFoam, when I write paraFoam, this line appears:
and as I'm using lab's computer, OpenFoam is installed in /sw directory, not in /opt directory, that's why couldn't do the process you have shown.
I found a similar line in the bashrc file: source /sw/etc/openFoam2.2.0_profile.sh
Could you please help me out how to fix this problem?
Old   July 7, 2013, 06:12
Retired Super Moderator
Bruno Santos
Greetings to all!
@Tariq: I've moved your latest question on this topic from the other thread to this one, so that we can keep this line of questions and answers on the same thread
OK, so you're using the lab's computer and I assume you do not have administrative permissions to install Qt yourself. So, there are two possible solutions:
  1. Talk to the person in charge of administering that computer and ask him to install Qt, so that you can use this ParaView version properly.
  2. If that person is not available, then you'll have to build Qt from source code. Problem is that you might not be able to build Qt from source code, if that machine does not already have the necessary build tools.
If you are not able to talk to the administrator, then we'll need to know which Linux Distribution you are using, so that we can guide you to a set of instructions that can allow you to build OpenFOAM and ParaView+Qt from source code.
Best regards,
Bruno
Old   July 8, 2013, 10:09
tariq
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Hi Bruno, thanks a lot for your help
somehow I have solved the problem, bt in a different way, got the solution from the tutorial here: http://www.openfoam.org/docs/user/cavity.php
In order to solve that problem, a dummy file should be created by typing:
touch cavityFine.OpenFOAM
Then paraview can be opened by typing:
paraview
Now the cavity case can be loaded into ParaView by selecting Open from the File menu, and having navigated the directory tree, selecting cavity.OpenFOAM.
I will ask the demonstrator about the points you said, let's see what he says
Thanking you once again!
parafoam, post processing, xfce desktop environment
FLUENT adjoint solution post processing? fangr FLUENT 0 April 13, 2015 11:15
[Q] CHEMISTRY POST PROCESSING takes a long time... Whitebear CFX 3 August 8, 2014 09:39
Problem in post processing Diana.N FLUENT 0 February 9, 2012 00:33
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
Post processing display problem Jennifer Haque CFX 2 January 18, 2002 11:01
