[OpenFOAM] paraview cannot read data from time directories |
June 7, 2013, 23:20 |
Yao Lu
Rep Power: 12 |
A case has been solved exactly, and post-processing is dealed with paraview.
Select internalMesh in Mesh Parts →select all Volume Fields →apply →read data successfully. 11.jpg Select all Mesh Parts →select all Volume Fields →apply →read data abortively. 22.jpg What's wrong with paraview and Mesh Parts? Thanks in advance. |
June 9, 2013, 15:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings shuoxue,
This is not the first time someone asks about this. And the great thing is that the other person also had shown the images of when it works and when it doesn't. - It was this one: http://www.cfd-online.com/Forums/ope...tml#post400799 - post #8 And the trick is simple: compare the two images and you'll see that in the first one you have near to middle top of the image, on the second row of controls, the text "Surface"; while on the second image, you have "Outline". This happens because ParaView tries to avoid very large meshes to be represented when it starts, which can lead to seriously slow start-ups, specially when people might not want to see all of the data right away. Best regards, Bruno
June 9, 2013, 23:15 |
Yao Lu
Rep Power: 12 |
I have tried according to your description, and it works.
Best regards. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
