Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Difference in magnitude in color bar and plot
Old   July 3, 2013, 08:07
Default Difference in magnitude in color bar and plot
vishal
vishal_s is on a distinguished road
The maximum magnitude in the color bar and the in the plot are showing different.Unable to understand why?.I have attached the plot and the magnitude bar.Please tell, how to sort this problem.
Thanks in advance
File Type: jpg Screenshot from 2013-07-03 17:37:22.jpg (36.4 KB, 9 views)
vishal_s is offline   Reply With Quote
Old   July 7, 2013, 06:15
Retired Super Moderator
Bruno Santos
Greetings Vishal,
You're not providing much information about this, so all I can do is guess
My guess is that your line plot is showing values inside the volume, while on the 3D image you're seeing the surface. And if the case is not 2D, then it's very likely that the values on the surface are much higher than inside the volume.
Use the "Slice" filter in the same zone where you have got the line for the plot, so that you can properly compare the results.
Best regards,
Bruno
[OpenFOAM] Plot over line average magnitude of particle velocity in paraview maysmech ParaView 13 August 12, 2022 11:46
contour plot: mass flow difference jai CFX 3 December 16, 2017 06:20
difference plot: turbulent kinetic energy (URANS) vs. Reynolds Stresses (LES) fabfi CFX 2 November 21, 2017 10:29
plot along a circle pcn90 FLUENT 2 May 7, 2017 06:41
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 15:40
