Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Python script for Integrate Variable
Like Tree2Likes
  • 2 Post By Eloise
Old   May 31, 2013, 05:09
Post Python script for Integrate Variable
Mehdi GHOZALI
Dadou is on a distinguished road
I am using paraview for visualize the velocity and the flow on a slice/clip that I did.
I have a lot of clips and I have to export data for every one and even the integrate variable data on this one. The first part is done now I don't know what is the sciprt of integrate variable on a clip so I can do it automaticly!!
hope some one will help
thank you in advance
dadou
Dadou is offline   Reply With Quote
Old   July 4, 2013, 10:25
Eloïse
Eloise is on a distinguished road
Hello Mehdi,
I'd like to do a similar scripted post-processing: integrate a variable on different clips and then export the spreadsheet data to a file. Have you made any progress on your case?
Regards,
Eloïse
Eloise is offline   Reply With Quote
Old   July 5, 2013, 03:37
Mehdi GHOZALI
Hi Eloise,
Nop any progress unfortunately, do you have any idea ?
Regards
Mehdi
Old   July 5, 2013, 04:02
Eloïse
Hi Mehdi,
I'm not sure it is the fastest way to deal with the csv files, but I did manage. Here is the interesting part of the script
try: paraview.simple
except: from paraview.simple import *
paraview.simple._DisableFirstRenderCameraReset()
import csv
surf = LegacyVTKReader( FileNames=['pathToImportFile.vtk'] )
RenderView1 = GetRenderView()
Clip1 = Clip( ClipType="Plane" )
Clip1.Scalars = ['POINTS', 'p']
Clip1.ClipType.Origin = [0.0, 0.0, 0.0] #can be a random origin point
Clip1.ClipType.Normal = [1.0, 0.0, 0.0]   #can be a random normal orientation
Clip1.ClipType = "Plane"
Clip2 = Clip( ClipType="Plane" )
Clip2.Scalars = ['POINTS', 'p']
Clip2.ClipType.Origin = [1.0, 0.0, 0.0]  #can be a random origin point
Clip2.ClipType.Normal = [-1.0, 0.0, 0.0]  #can be a random normal orientation
Clip2.ClipType = "Plane"
# we define the variable to be integrated on Clip2
Calculator1 = Calculator()
Calculator1.AttributeMode = 'point_data'
Calculator1.Function = 'writeHereTheFunctionOfYourVariable'
Calculator1.ReplaceInvalidResults = 0
Calculator1.ResultArrayName = 'NameOfYourVariable'
IntegrateVariables1 = IntegrateVariables()   #this integrates the current variable over Clip2
finalFile = open('pathToCSVFile.csv','wb')
fd = csv.writer(finalFile)
writer = CreateWriter('PathToATemporaryFile.csv', IntegrateVariables1)
writer.FieldAssociation = "Points"  # or "Cells"
for x in range(-6, 6): #loop through the origin point of Clip1
    print "We integrate from %1.1f to %1.1f" % (x,x+1)
    Clip1.ClipType.Origin = [x,0.0,0.0] #moves the first clip
    Clip1.ClipType.Normal = [1.0,0.0,0.0]
    Clip2.ClipType.Origin = [x+1,0.0,0.0] # moves the second clip
    Clip2.ClipType.Normal = [-1.0,0.0,0.0]
    writer.UpdatePipeline() # writes the integrated variable table to the tmp file
    # appends the integrated results of this Clip to the final csv file
    ftmp = open('PathToATemporaryFile.csv','rb')
    reader = csv.reader(ftmp, delimiter=',')
    row = reader.next()
    row = reader.next()
    fd.writerow([str(row)])
    ftmp.close()
finalFile.close()
del(writer)
Render()
If you know a way to make it faster, please share it I hope this will help you!
Eloïse
elvis and Bernhard like this.
Old   July 5, 2013, 05:38
Mehdi GHOZALI
I'll look it up.
Thank you so much for this, I'll see what I can do
Regards
Mehdi
[General] Python script to sum up a variable for all cells hconel ParaView 1 February 7, 2019 17:59
[General] python script to group/append datasets ufocfd ParaView 0 July 30, 2018 16:25
[OpenFOAM] Get cell center coordinates in a python script francois ParaView 2 June 3, 2017 08:20
[General] Using variables defined in a Python script on a Paraview/Python Calculator gafxian87 ParaView 0 June 8, 2015 13:18
[General] Using time in Python script lingdeer ParaView 0 August 11, 2014 01:57
