[OpenFOAM] Post processing problem in Xfce desktop environment using paraFoam |
June 24, 2013, 10:56 |
tariq
Rep Power: 12 |
I have been facing problem in post-processing using paraFoam. While doing the simple cavity tutorial (http://www.openfoam.org/download/ubuntu.php), after putting the paraFoam command these lines appears in the Terminal: created temporary 'cavity.OpenFOAM' /sw/openfoam/ThirdParty-2.2.0/platforms/linux64Gcc46/paraview-3.12.0/lib/paraview-3.12/paraview: error while loading shared libraries: libQtHelp.so.4: cannot open shared object file: No such file or directory What's the error here? As I'm new in Ubuntu and openFoam, have no idea about these typo errors!! the operating system is Xfce desktop environment https://en.wikipedia.org/wiki/Xfce Can anyone please help me out...
https://tariqridwan.github.io/ |
June 24, 2013, 13:53 |
#2 | |
Nima Samkhaniani
Rep Power: 24 |
try to install libQtHelp.so.4 , maybe you can use following command in terminal:
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
July 2, 2013, 10:43 |
#3 | |
tariq
Rep Power: 12 |
I'm also facing the same problem after doing blockMesh & icoFoam, when I write paraFoam, this line appears: created temporary 'cavity.OpenFOAM' /sw/openfoam/ThirdParty-2.2.0/platforms/linux64Gcc46/paraview-3.12.0/lib/paraview-3.12/paraview: error while loading shared libraries: libQtHelp.so.4: cannot open shared object file: No such file or directory and as I'm using lab's computer, OpenFoam is installed in /sw directory, not in /opt directory, that's why couldn't do the process you have shown. I found a similar line in the bashrc file: source /sw/etc/openFoam2.2.0_profile.sh Could you please help me out how to fix this problem?
July 7, 2013, 06:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Tariq: I've moved your latest question on this topic from the other thread to this one, so that we can keep this line of questions and answers on the same thread OK, so you're using the lab's computer and I assume you do not have administrative permissions to install Qt yourself. So, there are two possible solutions:
Best regards, Bruno
July 8, 2013, 10:09 |
#5 | |
tariq
Rep Power: 12 |
somehow I have solved the problem, bt in a different way, got the solution from the tutorial here: http://www.openfoam.org/docs/user/cavity.php In order to solve that problem, a dummy file should be created by typing: touch cavityFine.OpenFOAM Then paraview can be opened by typing: paraview Now the cavity case can be loaded into ParaView by selecting Open from the File menu, and having navigated the directory tree, selecting cavity.OpenFOAM. I will ask the demonstrator about the points you said, let's see what he says Thanking you once again!
parafoam, post processing, xfce desktop environment |
Display Modes | |
FLUENT adjoint solution post processing? | fangr | FLUENT | 0 | April 13, 2015 11:15 |
[Q] CHEMISTRY POST PROCESSING takes a long time... | Whitebear | CFX | 3 | August 8, 2014 09:39 |
Problem in post processing | Diana.N | FLUENT | 0 | February 9, 2012 00:33 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
Post processing display problem | Jennifer Haque | CFX | 2 | January 18, 2002 11:01 |
