[OpenFOAM] Paraview on Ubuntu
Like Tree1Likes
  • 1 Post By wyldckat
Old   September 16, 2013, 12:37
Default Paraview on Ubuntu
Tobi's Avatar
Tobias Holzmann
Hello all,
as Bruno mentioned in this thread: http://www.cfd-online.com/Forums/par...ering-gpu.html
I can compile Paraview in Ubuntu.
With
apt-get install paraview
everything was installed but after starting paraview I get the following error:
paraview: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory
MPI is installed on my computer, and the file which is missing is available:
shor-ty@cfd:~$ ls /usr/lib/libmpi.so
/usr/lib/libmpi.so
Can someone give me an advice?
Thanks Tobi
Old   September 27, 2013, 19:03
Retired Super Moderator
Bruno Santos
Hi Tobi,
Sorry for the late reply, but only now did I manage to get an idea (and time) on this: I'm guessing that the problem is that you have a conflict of ParaView versions. Or more specifically in this case, you might have a conflict of Open-MPI versions.
The idea is that when you want to use the ParaView version that Ubuntu provides, you should start it from the main applications menu, not from the terminal. Or use a clean terminal window that does not have the OpenFOAM environment loaded on the shell (Advanced tips for working with the OpenFOAM shell environment).
The other idea is that to avoid conflicts of Open-MPI versions, you should always use the Open-MPI version provided by Ubuntu. In other words, use "WM_MPLIB=SYSTEMOPENMPI" as explained here: http://openfoamwiki.net/index.php/In...M-2.2.0/Ubuntu
Best regards,
Bruno
babakflame likes this.
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 05:49
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 18:00
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 21 September 17, 2009 11:27
[OpenFOAM] Paraview 3.4, ppa.launchpad.net and Ubuntu francois ParaView 1 May 29, 2009 09:07
