[OpenFOAM] how to get the paraview parallel run
Like Tree1Likes
  • 1 Post By fabian_roesler
Old   January 20, 2014, 06:13
Default how to get the paraview parallel run
luchen
luchen2408 is on a distinguished road
I worked on a client and connect with the server(24 cores) by freeNX, I can perform the simulation parallel with openfoam and I can post-process the result with single core by paraview, but I think it is a little slow once I check the result. I want to parallel run the result with paraview. I don't know how to configure the server and client? first I am testing on a single computer with multiple cores? but all failed. can you give me any guidance?
luchen2408 is offline   Reply With Quote
Old   January 23, 2014, 03:40
luchen
hello, is there anyone know how to parallel the paraview? I got a 24 cores server and I connect it by freeNX. I want to render a big case with parallel run. is there anyone know how to do it?
Old   January 23, 2014, 10:05
Default mpirun pvsever
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
the OpenFOAM reader is, as far as I know, not parallel. However, you could use the paraview native server and a mpirun. I never tried but it would look like this:
touch case.foam
mpirun -np CPUs pvserver -parallel
Touch the case with the Foam reader or every processor of a decomposed case with the OpenFOAM reader.
Fabian
kaifu likes this.
fabian_roesler is offline   Reply With Quote
Old   January 23, 2014, 17:49
Retired Super Moderator
Bruno Santos
Greetings to all!
To add to Fabian's answer, I'll quote myself from another thread:
Originally Posted by wyldckat View Post
You can try turning on the multi-core feature that ParaView has got, if it was built with MPI capabilities, which is accessible at the Settings dialogue, namely the check box "Use Multi-Core": http://www.paraview.org/Wiki/ParaVie...Guide/Settings
This feature allows you to not have to run manually pvserver with mpirun, since ParaView will do this for you.
Nonetheless, keep in mind that using multi-core does not always equate to faster performance.
Best regards,
Bruno
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches Armin.Sh OpenFOAM Running, Solving & CFD 7 March 28, 2021 22:33
[OpenFOAM] Questions about Paraview to show Parallel run of OpenFOAM padian ParaView 20 September 24, 2018 12:52
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 11:20
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
