Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Plot the spreading of oil on the surface of water over time
Old   April 27, 2013, 17:49
Default Plot the spreading of oil on the surface of water over time
Guifan Li
liguifan is on a distinguished road
Good afternoon everyone!
I am working on a case that measure the oil spreading over water and I want to measure how the oil behaves over time.
Now I am able to visualize the oil spreading, however, I am not able to plot the spreading of oil from central to the wall boundary.
As far as I can think of is to use the filter: plot selection over time. I used a clip filter to exact the water only and select the surface of the water then use Plot selection over time filter to do it, but it doesn't seem to be working.
Does anyone have any idea about how to do this?
Thanks in advance.
liguifan is offline   Reply With Quote
Old   April 28, 2013, 06:33
Retired Super Moderator
Bruno Santos
Greetings liguifan,
Try the instructions from this thread: http://www.cfd-online.com/Forums/par...-analysis.html
Best regards,
Bruno
Old   May 21, 2013, 17:07
Guifan Li
Hi Bruno,
Thanks for the reply, I followed you instruction from the other thread, however, in the test case provided, you have fixed a position and measure the height change in that position. In my case, the point I am interested is spreading over the surface of the water.
If I use alpha=0.5 in the coutour, it will show the whole surface of the water, not just the oil on the surface, but what I am interested is plot the distance of oil spread on the water surface VS time.
Do you have any ideas about that?
Originally Posted by wyldckat View Post
Greetings liguifan,
Best regards,
Bruno
Old   May 21, 2013, 17:35
Bruno Santos
Hi Guifan,
Well, the other example allows us to tell apart water from air by using the contour "alpha=0.5", because "alpha=1" is water and "alpha=0" is air.
But in your case, I do not know how you can tell apart water from oil, because I do not see what you're seeing!
What values/fields can you use to tell the two apart?
Best regards,
Bruno
Old   May 21, 2013, 17:46
Guifan Li
Hi Bruno,
Please have a look at these two photos, the first one shows that there are three phases, red one is air, white one is oil and blue is water. This is a wedge.
The alphawater =0 alphasoil=1 and alphaair=2.
The second photo is to use the clip filter to filter out the oil, so that you can see the oil only spreading on the surface of water.
Hi Guifan,
Best regards,
Bruno
Old   May 21, 2013, 18:03
Bruno Santos
Hi Guifan,
Then it should be very simple: when you apply the "Contour" filter, you can choose more than one value. In this case, you can pick "0.5" and "1.5"!
Best regards,
Bruno
Old   May 21, 2013, 18:14
Guifan Li
This is to separate the water and oil and air oil, but how can I plot the moving oil VS time if you have any idea?
I will give it a try tonight see what happens.
Best,
Guifan
Hi Guifan,
Best regards,
Bruno
Old   May 21, 2013, 18:27
Bruno Santos
Hi Guifan,
Oh, sorry, I forgot about that particular detail of tracking the whole surface instead of a single point.
I've done a quick test and I think the following steps can help a bit:
  1. Apply the "Contour" filter with the mentioned values "0.5" and "1.5".
  2. Apply the filter "Plot Data".
    1. Go to the tab "Display" in the "Object Inspector".
    2. Select as "X Axis Data" to use the array "Points(0)".
    3. Select in "Line Series" to use the array "Points(1)".
    4. Line style -> None
    5. Marker Style -> Cross
Best regards,
Bruno
Old   May 22, 2013, 14:30
Guifan Li
Hi Bruno,
I tested you method today, and got something as shown in the picture. The rectangular is the initial oil and the second picture is the oil film after a few seconds. As you can see, the upper bound of the plot is the outer boundary of the oil film on the surface of water, which is pretty good for now. But I am not sure why the plot is like this, looks quite messy. And I want to plot the upper bound( the max value of the plot) VS time. Do you have any idea about that?
Btw, why we need to mark the style as cross?
Thanks for that.
Hi Guifan,
Best regards,
Bruno
File Type: jpg Screen Shot 2013-05-22 at 1.56.34 PM.jpg (44.2 KB, 27 views)
File Type: jpg Screen Shot 2013-05-22 at 1.57.01 PM.jpg (45.8 KB, 26 views)
Old   May 22, 2013, 18:12
Bruno Santos
Hi Guifan,
Isn't that just a matter of only getting the contour for the upper interface? The "1.5" perhaps?
Because this method does not sort the points by the order of connection.
Wait, I've done a few more tests and remembered about the "Plot on Sorted Lines" filter, which is shown in the attached image. Use this filter instead of the "Plot Data".
Another detail to look for is the "DataSet" blocks shown on the lower left part of the image, inside the "Select Block" tree. It looks like we can only show one line at a time, in case they become disconnected.
By the way, I used the "Slice" filter in order to make it easier plot the data.
Best regards,
Bruno
File Type: jpg Screenshot from 2013-05-22 23:08:42.jpg (44.4 KB, 17 views)
Old   January 29, 2014, 08:19
Default Spread plot over 3D contour
  #11
Bernhard Linseisen
Linse is on a distinguished road
Dear all,
seems I have some difficulties in the transfer of this solution to my problem:
I have a gas cloud extending within a tunnel. Producing the contour at the different timesteps is not a problem. (see attached image)
But for proper comparison to other simulations (and experimental data at some point) I would need to have the propagation speed of the cloud front (i.e. the position of the most-forward point of the contour).
The steps I see are:
- get the contour (works nicely)
- get the point most distant from the reference plane (origin) (not working yet)
- plot the specific coordinate of that point (needs the point)
- make the plot over time (needs the previous data)
Anybody with an idea how I can get to the goal?
Thanks for any answer in advance!
Cheers,
Bernhard
Linse is offline   Reply With Quote
Old   February 2, 2014, 07:51
Bruno Santos
Greetings Bernhard,
Well, in your case, the only solution is to rely on the filter "Programmable Filter": http://www.paraview.org/Wiki/Python_Programmable_Filter
Here's what I tested and worked:
  1. Open your case.
  2. If you are opening multi-block data (it's the case with OpenFOAM results), then the first filter is to apply the "Merge Blocks", so that it's easier to create the script.
  3. Apply the Contour script.
  4. Apply the "Programmable Filter":
    1. Choose the "Output Data Set Type" to be "vtkPolyData".
    2. "Script":
      pdi = self.GetPolyDataInput()
      pdo =  self.GetPolyDataOutput()
      pdo.Allocate(1, 1)
      newPoints = vtk.vtkPoints()
      numPoints = pdi.GetNumberOfPoints()
      maxLocation = [-2.0e300, -2.0e300, -2.0e300]
      for i in range(0, numPoints):
          coord = pdi.GetPoint(i)
          if coord[0] > maxLocation[0]:
             maxLocation = coord
      newPoints.InsertPoint(0, maxLocation[0], maxLocation[1], maxLocation[2])
      pdo.SetPoints(newPoints)
    3. Keep the entry "RequestInformation Script" empty.
    4. Apply.
  5. Now use the view splitter and choose the "Spreadsheet view".
  6. In the "Spreadsheet view", choose to see the entry for the "ProgrammableFilter1".
  7. Click on the only listed point in the "Point Data" attribute.
  8. Apply the filter "Plot Selection Over Time" and click on the "Copy Active Selection" button. Then Apply.
    • Go into the tab "Display" and be sure to pick the "Point Coordinates (0)", so that you get the correct plot.
The problem is that this particular script will lock up on the first point that is found. If you have multiple points at the tip, then you'll need to do an average of all points at the maximum X:
pdo.Allocate(1, 1)
maxLocations = []
       maxLocation = coord
       maxLocations = [maxLocation]
    elif abs(coord[0] - maxLocation[0]) < 1.0e-5:
       maxLocations.append(coord)
maxLocation = mean(maxLocations)
By the way, this line:
pdo.Allocate(1, 1)
is for wiping out the cell list, otherwise it will think it should have the same number of cells as the original input.
Best regards,
Bruno
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 00:58
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 10:54
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
