Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] About StreamTracer of paraView
Old   October 14, 2015, 05:02
Default About StreamTracer of paraView
KeiJun is on a distinguished road
Dear Sir,
I calculated gas flow, and visualized the result using StreamTracer of paraView, but the stream line was broken unnaturally. (See the attached pictures)
Could you advise me how to make natural stream lines (not broken)?
And does the StreamTracer tend to make such unnatural lines?
If so, could you tell me alternative visualization (not Stream Tracer) to visualize the trace of the gas flow?
Here, setting conditions are:
  Max Streamline Length…10, Seed Type…High Resolution Line Source,
  Line…X Axis, Resolution…100.
I am looking forward to your reply.
Sincerely
KeiJun
KeiJun is offline   Reply With Quote
Old   October 14, 2015, 13:53
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Are you plotting the streamlines on a 2d slice of a 3d simulation?
kmooney is offline   Reply With Quote
Old   October 15, 2015, 00:27
Dear Kmooney,
Thank you for your reply.
I make the streamlines on a 3D (below the ***.OpenFOAM).
The streamlines on a 2D slice I made is attached, which is more unnaturally than that on a 3D.
KeiJun
Old   October 15, 2015, 14:12
Damian B.
FluidDam is on a distinguished road
What's about using the LIC Filter ?
See
http://www.paraview.org/Wiki/ParaVie...al_Convolution
FluidDam is offline   Reply With Quote
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
[OpenFOAM] paraview streamtracer dshawul ParaView 0 November 11, 2010 17:11
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
