Home > Forums > Visualization & Post-Processing Software > ParaView
[General] Streamlines on 3D surfaces
Old   December 6, 2015, 19:07
Default Streamlines on 3D surfaces
Antonio
antoniop is on a distinguished road
I would like to know if Paraview gives the possibility to plot streamlines on a 3D surface.
For instance, I use a STL file as triangular 3D surface grid where to plot contours of a scalar. I adopt a HDMF file to load the data I need, as below:
<?xml version="1.0" ?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf xmlns:xi="http://www.w3.org/2003/XInclude" Version="2.2">
<Information Name="MetaData" Value="ID-23454"/>
<Domain>
<Grid Name="STL Grid" GridType="Uniform">
<Topology TopologyType="Triangle" Dimensions="86394">
<DataItem Dimensions="86394 3" NumberType="Int" Precision="4" Format="HDF">
Eppler387_2chords_angle10.h5sp:/conn
</DataItem>
</Topology>
<Geometry GeometryType="XYZ">
<DataItem Dimensions="43199 3" NumberType="Float" Precision="4" Format="HDF">
Eppler387_2chords_angle10.h5sp:/vert
</DataItem>
</Geometry>
<Attribute Name="cf" AttributeType="Scalar" Center="Node">
<DataItem Dimensions="43199" NumberType="Float" Precision="4" Format="HDF">
cf_ibd0001.vno.h5sp:/var
</DataItem>
</Attribute>
</Grid>
</Domain>
</Xdmf>
Can I load on the same grid a vector and then use it to generate streamlines over the 3D surface?
Thanks
Antonio
antoniop is offline   Reply With Quote
Old   December 8, 2015, 04:16
Retired Super Moderator
Bruno Santos
Quick answer: http://www.cfd-online.com/Forums/par...tml#post368108 - post #3
3d surfaces, stl file, streamlines
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan ANSYS 6 June 8, 2015 07:33
Problem regarding producing streamlines from surfaces in Ansys CFD post gauthamnarayan Visualization & Post-Processing 0 April 23, 2015 16:07
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 10:13
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 04:12
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 13:33
