"Data Range Too Small To Render" Cavity Tutorial
Hello, I am following the cavity tutorial provided from sourceforge.
I have not run into any problems executing the case in the termal, but when I go to view pressure contours in paraview I get a solid rendering instead of colour gradients representing the pressure. In playing around with the Color Map Editor I see a message stating "Data Range Too Small to Render." I did not get any obvious error messages when I ran the case, but I will post the terminal i/o. Unfortunately, I am learning this on my own and dont have access to professors (or anyone for that matter) who is experienced with the software. Any help is appreciated change directory Code:
=> cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity Code:
=> blockMesh Code:
=> icoFoam Code:
Time = 0.5 Code:
paraFoam |
Ah... Well I figured it out. In Paraview I had the 0th time step selected, which by default would not have any gradients shown. After selecting t=.5 seconds I got the correct rendering
