[OpenFOAM] [N00B_Q] Need Help with Ploting Water Height Over Time |
September 1, 2015, 16:17 |
Cagkan
Rep Power: 10 |
I'm modelling a 2D channel with wall in it, using IHFoam to produce waves and solve it with IHFoam. The wall has holes in it so some part of the waves are passing thru some of it reflecting back.
I'm trying to measure the water height in front of the wall (5cm away on the approach side) and plot a water height over time graph. Tried to use surface condition (alpha1=0.5) but at some time step air pockets occur and water level readings became wrong. How can i make it choose the highest alpha1=0.5 to make it right? Steps that i use: 1- Contour alpha1 = 0.5 2- Calculate
4- Viewing the slice as a spread sheet then i choose point0 to plot the water level. Most of the time it reads 3 different points with same water level but some times it reads more than that but it keeps reading the point0 even if it is not the highest point. check the screen shots I'm a newbie so please be as clear as possible when answering Thank you! |
ihfoam, openfoam, parafoam, plot, water level |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
