[OpenFOAM] Error with using of pvbatch on Super Computer |
November 17, 2015, 23:52 |
Baris (Heewa)
Rep Power: 13 |
Dear All,
I am carrying out a large scale simulation by connecting to a Super Computer using OpenFOAM. Due to huge data, I am using python script via pvbatch option to get the data automatically. OpenFOAM and separetely paraview is already available in Super Computer. I cant use internet within super computer and I am only allowed to install program into my home location within SUPER PC. Details of Super computer: Red Hat Enterprise Linux Server release 6.6 When I run the following run.sh file inside Super PC with python script using: sbatch run.sh run.sh file Code:
SBATCH -p g006m #SBATCH -N 1 #SBATCH -n 1 #SBATCH -J VOF_100M #SBATCH -o stdout.%J.log #SBATCH -e stderr.%J.log module load PrgEnv-gnu482 module load gnu/openmpi165 export PATH=/home1/share/Qt/4.8.0/gnu/bin/:/home1/share/cmake/2.8.12/bin/:/home1/share/openmpi/1.6.5/gnu/bin/:/home1/share/gcc/4.8.2/bin/:/home1/share/p$ export LD_LIBRARY_PATH=/home1/share/Qt/4.8.0/gnu/lib/:/home1/share/openmpi/1.6.5/gnu/lib/:/home1/share/gcc/4.8.2/lib64:/home1/share/python/2.7.6/lib/:$L$ /home1/share/paraview/4.0.1/gnu/openmpi/bin/pvbatch --use-offscreen-rendering PlotImage.py Code:
librdmacm: Fatal: no RDMA devices found -------------------------------------------------------------------------- [[14715,1],0]: A high-performance Open MPI point-to-point messaging module was unable to find any relevant network interfaces: Module: OpenFabrics (openib) Host: g002 Another transport will be used instead, although this may result in lower performance. -------------------------------------------------------------------------- /tmp/slurmd/job528788/slurm_script: line 3: 4736 Segmentation fault /home1/share/paraview/4.0.1/gnu/openmpi/bin/pvbatch --use-offscreen-rendering PlotImage.py Thanks in advance. Baris |
November 18, 2015, 02:28 |
Since your script run in serial mode, you can ignore error message till the second line of minuses (well, you can ignore it even for parallel run in fact). So the error is: Code:
.../slurm_script: line 3: 4736 Segmentation fault .../pvbatch --use-offscreen-rendering PlotImage.py Since you are installing everything into home folder, guess the problem could be in conflicting/missing libraries. |
November 18, 2015, 03:04 |
Baris (Heewa)
Rep Power: 13 |
Dear Alexey,
First, thank you for reply. Truly speaking, I just meant that I am only allowed to install into my home directory within SUPER computer but I did not install anything. For OpenFOAM calculation I have just used the already installed OpenFOAM within the share folder of SUPER PC by linking where it is. I just run the parallel using following run.sh file for openfoam case and it worked: Code:
!/bin/bash #SBATCH -p d072h #SBATCH -N 5 #SBATCH -n 100 #SBATCH -J VOF_100M #SBATCH -o stdout.%J.log #SBATCH -e stderr.%J.log module load PrgEnv-intel module load intel/openmpi165 source /home1/share/openfoam/2.1.x/intel/openmpi/OpenFOAM-2.1.x/etc/bashrc mpirun -np 100 pimpleContamiFoam10_SF1R -parallel Actually, I tried to install of Paraview into my home directory, however, since I can not connect to internet within super PC, it was quite cumbersome, like I have to install all the depended packages one by one and compile within my home folder. Therefore, I gave up this and decided to use already installed paraview within share folder of SUPER PC like openfoam. The PlotImage.py is only a kind of test case whether we can get data using pvbatch option or not. I already tried it in my desktop pc and it worked. this is the content of PlotImage: Code:
try: paraview.simple except: from paraview.simple import * #---Connect("hostName", try: paraview.simple except: from paraview.simple import * #---Connect("hostName", portNo) #Connect("f0", 11111) Column_foam = OpenFOAMReader( FileName='../Column/Column.foam' ) Column_foam.UpdatePipeline(1000) RenderView1 = GetRenderView() #----Time RenderView1.ViewTime = 1000 #----Background Color (Default) RenderView1.Background = [0.32941176470588235, 0.34901960784313724, 0.42745098039215684] #----Axis on or off RenderView1.CenterAxesVisibility = 0 #----OffscreenRendering off #---- When you use "pvserver --use-offscreen-rendering" "with osmesa", set both of them 1 RenderView1.UseOffscreenRendering=0 RenderView1.UseOffscreenRenderingForScreenshots=0 #----Window size RenderView1.ViewSize=[949,706] #-----Color Table r=Column_foam.PointData['p'].GetRange() #----RGBPoints=[BeginValue, r, g, b, EndValue, r, g, b] a1_p_PVLookupTable = GetLookupTableForArray( "p", 1, \ RGBPoints=[r[0],0,0,1, r[1],1,0,0], \ NumberOfTableValues=30, \ ) #-----Color of Body DataRepresentation2 = GetDisplayProperties(Column_foam) DataRepresentation2.Representation = 'Surface With Edges' DataRepresentation2.ColorArrayName = 'p' DataRepresentation2.LookupTable = a1_p_PVLookupTable #DataRepresentation2.ScalarOpacityFunction = [] #DataRepresentation2.ScalarOpacityUnitDistance = 0.014374810608995429 #-----Color of Bar #---Position:Position of the bar. Position2:Scale of the bar. ScalarBarWidgetRepresentation1 = CreateScalarBar(\ Title='p[Pa]', \ Position2=[0.1, 0.5], \ Enabled=1, \ LabelFontSize=12, \ TitleFontSize=12, \ Position=[0.05, 0.4]\ ) ScalarBarWidgetRepresentation1.LookupTable = a1_p_PVLookupTable GetRenderView().Representations.append(ScalarBarWidgetRepresentation1) #-----Camera RenderView1.CenterOfRotation = [0.00039450079202652,0.000110898166894913, 0.5] RenderView1.CameraViewUp = [0.21641266854759553, -0.8239812714933662, 0.5236605972576934] RenderView1.CameraFocalPoint = [0.00039450079202627014, 0.0001108981668950143, 0.49999999999999983] RenderView1.CameraClippingRange = [1.1126808662010967, 3.137745671346546] RenderView1.CameraPosition = [1.3484326860003855, -0.5289963646916971, -0.8896539475806535] Render() WriteImage("image.png") Code:
Does it work at all (i.e. what will be the result of the slurm script is you just run 'pvbatch --use-offscreen-rendering --version')? Does your PlotImage.py work at all? HTML Code:
-bash: pvbatch: command not found Thank you |
November 18, 2015, 04:14 |
Obviously this Code:
-bash: pvbatch: command not found This part of your script conflicts with --use-offscreen-rendering flag you pass to pvbatch. Code:
#----OffscreenRendering off #---- When you use "pvserver --use-offscreen-rendering" "with osmesa", set both of them 1 RenderView1.UseOffscreenRendering=0 RenderView1.UseOffscreenRenderingForScreenshots=0 |
November 18, 2015, 04:41 |
#5 | ||
Baris (Heewa)
Rep Power: 13 |
Hi Alexey,
thank you for reply. Quote:
Regarding to your following remarks, Quote:
RenderView1.UseOffscreenRendering=1 RenderView1.UseOffscreenRenderingForScreenshots=1 Code:
librdmacm: Fatal: no RDMA devices found -------------------------------------------------------------------------- [[34111,1],0]: A high-performance Open MPI point-to-point messaging module was unable to find any relevant network interfaces: Module: OpenFabrics (openib) Host: g001 Another transport will be used instead, although this may result in lower performance. -------------------------------------------------------------------------- ERROR: In /root/paraview/gnu/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx, line 531 vtkXOpenGLRenderWindow (0x21b74d0): bad X server connection. DISPLAY=ERROR: In /root/paraview/gnu/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx, line 322 vtkXOpenGLRenderWindow (0x21b74d0): bad X server connection. DISPLAY=/tmp/slurmd/job529292/slurm_script: line 18: 31332 Segmentation fault /home1/share/paraview/4.0.1/gnu/openmpi/bin/pvbatch --use-offscreen-rendering PlotImage.py Thank you. |
November 18, 2015, 04:56 |
Google is quite useful thing. https://www.google.fr/search?q=pvbat...reen+rendering And the first link is... http://www.cfd-online.com/Forums/par...rendering.html |
[General] Paraview parallel processing with pvbatch | wouterremmerie | ParaView | 2 | February 26, 2020 10:41 |
Two computer cluster - problems with settings | dradenkovic | OpenFOAM Running, Solving & CFD | 9 | November 13, 2017 04:16 |
Some advices to buy a computer | migmolper | Hardware | 8 | July 11, 2016 15:52 |
Using Remote Solve Manager for Single Computer | u2berggeist | ANSYS | 1 | May 21, 2016 21:01 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
