[OpenFOAM] ParaView-4.4.0 with older OpenFOAM-2.1.x
Old   July 8, 2016, 04:06
Post ParaView-4.4.0 with older OpenFOAM-2.1.x
Mathi
fluidmobil is on a distinguished road
Hello all,
I installed OpenFOAM-3.0.1 successfully together with ParaView-4.4.0.
For comparing older results I had to install OpenFOAM-2.1.x additionally. That was successful too. But now I wanted to use ParaView-4.4.0 with this OpenFOAM-2.1.x too, but when I start paraFoam I get the message
hartwich@EVT111:~/OpenFOAM/hartwich-2.1.x/run/cavity> paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
I already tried to start paraFoam with
paraFoam -builtin
but this doesn't work.
I also tried to paste the line
export PATH=$PATH:/opt/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0/bin
to the
/opt/OpenFOAM/OpenFOAM-2.1.x/etc/bashrc
the result was the same.
How is it possible to use ParaView-4.4.0 with OpenFOAM-2.1.x?
Thanks for help
Mathias
fluidmobil is offline   Reply With Quote
Old   July 8, 2016, 04:30
Mathi
additional info:
after adding the line
export PATH=/opt/OpenFOAM/ThirdParty-3.0.1/platforms/linux64Gcc/ParaView-4.4.0/bin:$PATH
to my $HOME/.bashrc file I could start paraview to visualize my case.
But paraFoam is still not working and gives the message
./Allwclean
./Allwmake
How can I get paraFoam running?
Thanks for help
Updated native OpenFOAM reader for ParaView 5.3 opencfd OpenFOAM Announcements from ESI-OpenCFD 4 July 13, 2017 10:14
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 ad2eb OpenFOAM Installation 12 May 28, 2017 14:30
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case romant ParaView 3 April 7, 2014 15:42
